View Full Version : Ford Escape Hybrid
Pages :
1]
13
16
- AC in negative function mode. Ideas or tips welcome
- Engine oil cooler?
- 2009 FEH PTU drain plug found
- 2010 Escape Hybrid Freeway P0A7C & SSN
- Confused about EV Chargers: Home vs Public Options?
- 2009-2012 Escape Brake Simulator c1012
- 09 FEH -Stop Safely even After Charge
- 06 Escape Hybrid starts for 2 sec and dies HELP🙏
- Complete battery core availible
- 2008 FEH 154k sensor covered with oil
- 2009 FEH no power assist for braking
- 2006 FEH ScanGuage 2
- 2008 Ford Escape Hybrid trying to install grid charger but 0V at leads
- ABS OUTDOOR_TEMPERATURE -7 c
- 2008 Escape Hybrid HV goes low after a few days
- Add 12v jump-start module to 09+
- 2009 FEH Brake DTC codes
- Lessons learned on 2009 FEH
- After replacing the ignition switch, the car won’t start because the system locks it
- 2005 Ford Escape Hybrid, No com with TBCM, No relevent codes
- P2afe
- 2008 FEH Starts, then dreaded Stop Safely Now immediately
- Dash bulbs
- 2008 Escape Hybrid - P0A1F-20
- HV battery charging
- MOT Retest Confusion – Do I Have to Pay Again?
- Acorns in my 09 FEH engine air filter
- 11 escape hybrid no HVB voltage??
- 2008 FEH BCM Replacement
- no start condition..
- 08 Ford escape hybrid
- Reconditioned HV battery conundrum
- 2010 Ford Escape Hybrid Door Trim Panel Insert Replacement?
- 08 Escape SSN Hybrid Bat NO CRANK NO START
- 09 feh C1014 and bubbles in rear brakes
- Green Bean, Bumblebee Battery Fail
- MPG city / hwy was 34 city legit
- NO Brakes * check brake system, clear codes?
- Intermittent steering column rattle
- Help for hv battery
- C1018:46:ab
- FEH wows
- A/C Recharge?
- Research on the FEH Battery
- 2008 Escape high/low a/c pressure lines discontinued
- Mew member: FEH back on the roads again
- 12v outlet always on
- 2006 FEH P0A1F and LOS Status
- 2009 FEH No crank no start
- Best way to charge and test OEM NiMH battery sticks?
- YouTube video series converting HVTB to Li-Ion
- Rebuild Complete. New MaxPower battery sticks. '09 FEH.
- 2010 FEH - Tube disconnected not sure what it is…
- Ford Escape Hybrid Braking System Writeup
- Quick help needed: P0A17 OBD-II: Motor Torque Sensor Circuit code
- no power steering and code U2023
- 2010 Ford Escape Hybrid Power Assist Failure C1012 Brake Pedal Feel Solenoid
- Preparation for 1month storage
- About to rebuild my '09 HVTB with MaxPower...some questions
- 2009 escape hybrid ev motor seems to work but gas engine not starting
- 2023 phev
- looking for a part that goes from battery to ventilation system
- 2020 Escape Hybrid Noise in Reverse
- Forscan balancing and battery data
- 2023 FEH Active 8" screen Sub install
- lack of A/C cooling for the battery
- 2009 Mariner Hybrid: Brake's aren't Brakin'... Sometimes
- Tips for first time buyer
- Sudden Date/Time Reset/Change
- 2008 Ford Escape jump start button blinking
- 2011 Ford Escape Hybrid "Stop Safely Now"
- 08 FEH, high revs when hill climing
- P1A0C-00 is this a issue
- Stop Safely Now
- 2006 FEH SSN (Again)
- 2005 Escape Hybrid Wont Start
- Power steering
- S Keith: Please help with HVTB drain issue, possibly ignition module related
- Source for A/C solenoid valve
- 2009 MMH No Crank No Start
- Deep cycle charge using the "jump button"
- 2008 Ford Escape throttle body
- Advice for a new 2010 Escape Hybrid owner?
- 2006 FEH Electrical Issues
- 2009 FEH P1450-C Check engine code
- Conservative approach to battery management with 14.4 KW Hybrid Lithium Battery
- New 12V battery. Jump start sucessful but motor dies in 5 to 10 seconds.
- Replacing the DC/DC inverter / converter
- Can any years of the Escape Hybrid run the Air Conditioner all night for camping?
- 2006 FEH - Changing Brake Hoses
- 09 FEH wrench light no codes
- brake issuue, anyone else get this pulse
- Best brake fluid? - 2008 FEH
- A/C mechanic in Seattle area that understands 2008 FEH?
- ABS C1018 : 46-AB code - No brakes!?
- '09 Armrest/Center Console Lid Removal? Help needed, please.
- Puzzler ABS + Stability Control Lights 2010 FEH
- 2010 Escape Hybrid snap sound
- C1029 Code and ABS/Skid/Brakes lights on 2010 FEH
- Unable to jumpstart 2020 FE Hybrid
- 2009 feh starting issues after replacing 12v.
- Six Degree Cold Start 2010 FEH - Coldest Yet!
- 2008 FEH with HV battery issues? Maybe?
- Periodic Orange Wrench - ‘09 MMH
- Winter Tire Switcharoo 10 FEH Limited 2WD
- 2006 Hybrid Gear Grind?
- P0442 code
- 2007 FEH MPG woes? Where do I start?
- First Cold Start on ICE Event Today
- 2006 FEH HV Battery On its Way Out
- Catalytic Converter Theft
- 2021 Ford Escape manual park override
- Adding "scoop" to HV battery air inlet?
- Winter Tire Recommendations - 2010 FEH 2WD
- 2008 FEH battery bad?
- 2022-23 Ford Maverick Hybrid WOW
- 2009 FEH Wrench & Engine Light - P2450
- when should battery blend door be open vs closed
- 2010 FEH No Start - Stop Safely Now
- Question, anyone with a '21-'22 FE PHEV
- 2010 FEH Limited with SSN and multiple codes - Help!
- AC mechanic in San Diego or So Cal that already understands 2009 MMH
- Hi everyone new here and looking 4 help
- Lack of accelerator response first thing in AM
- Long Highway Trip MPG Report Coming - '10 FEH Limited
- Gotta love the wife 😡 Now what are my options
- Best FEH Year for battery longevity
- Trailer Wiring
- 2006 Ford Escape Hybrid battery failing
- A Sticky Idea....Normal/Abnormal FORScan Values
- Lost the power assist on the brakes on my 2010 MMH
- 2008 FEH: It's not 'hybriding.'
- Alternate battery cells for FEH
- 2009 FEH Battery options
- 2009 FEH broken relay ring terminal
- No EV mode after rear brake job
- 2009 FEH - p0a7c (again..)
- HV Battery not cooled by AC
- Change your Air Filter!
- 2009 FEH new owner seeking Torque App PIDs
- 2006 FEH - HCU Failure?
- Update: Two years in a 2010 FEH Limited 2WD
- My 2007 FEH can't hold a charge overnight (131,000 miles)
- 2008 2.5L Ticking on cold start
- 09 FEH car sit only 2 days, won't start
- How do you reuse the battery sticks from the HV battery?
- 2008 FEH Motor Coolant Flush Procedure
- Should have listened to S.Keith. 😢
- NEW Replacement Battery Cells.
- Should I buy a 2008 Escape Hybrid?
- Bought a fixer upper Ford Escape Hybrid and have some quest
- Transmission issue?
- Acquired escape hybrid with bad crank shaft
- 2009 Escape My first Hybrid, could use some advice
- E85 conversion kit
- 2008 FEH - Possible HCU replacement
- '09 MMH AWD Poor Gas Mileage
- '09 FEH P0AA7/Wrench Light help, please.
- Passenger Front Wheel Hub/Bearing Grrrrr Escape Hybrid Limited 2010 2WD
- 2007 Ford Escape Hybrid cut out/shudder under medium acceleration - CVT Transmission?
- 2010 vs 2012
- 2006 Escape Hybrid with a mystery Aux In Port; can’t figure out how to use it.
- New to Hybrid - With Questions
- Newbie Q: Is it OK to advertise tires I'm selling for a 2020-22 FEH here?
- New Escape Hybrid Owner Confused
- p0128 again..
- Stalls in neutral
- 08 Brake pedal travel sensor failed C1524
- Service Emission System Warning-No Code 2006 FEH
- Service Emission system alert but no code
- Hatch Glass Weatherstrip Refurbish Attempt - 2010 FEH
- 2009 ford escape hybrid battery recharge
- Blower Motor One Speed 2010 FEH Limited
- 2005 FEH (!) BRAKE Light
- 2007 FEH Intermittent start and stall
- Updated 2010 Navigation System to 11.0X
- 2006 FEH - Red Triangle of Death/throttle body/airflow issue
- 2006 FEH - Red Triangle of Death/throttle body/airflow questions
- 2009 FEH not going into reverse
- How Many Battery-Backed Modules are in an FEH?
- Where is the TPMS error code stored on a 2007 Escape Hybrid
- 2007 FEH w/ 140K Miles
- Ford Dealership Destroyed my Escape while working on it, what now?
- New Hybrid Owner - 2008 Escape - EV Mode
- P0A1f
- FEH Battery Differences Between Years/Other questions
- Feh 2005 after 6 years sitting
- Help! My car stopped playing Mp3s FIX
- Thinking about getting my first hybrid- 2010 ford escape. Is this a good car?
- 2007 Ford Escape Hybrid won’t start ($100 to whoever gives me the right solution)
- Stop Safely Now & red triangle
- First Wrench Light 2010 Escape Hybrid
- Bad electric motor?
- Greentec Auto battery woes
- TPMS and Valve Stems on Factory '10 FEH Wheels
- Onboard charger question
- Ford Escape 2011 Hybrid Problem
- 2009 Ford Escape Hybrid idle for 4 months, Cant jump start
- 2010 feh dashboard photos evmode assist regen
- Measuring HV battery “health”
- 07 FEH AC woes
- '05 FEH- Several Questions
- Codes on all 4 coils with no end in sight
- Oil Change 10k FEH 2010
- something to NOT try with the heads up display
- Buying a Used 2011 Ford Escape - What to look for?
- New hybrid battery replacement won’t start
- 2010 FEH USB Port - Is It 2.0?
- Steering Wheel Cover Review - 2010 FEH
- 2005 FEH - What To Do?
- Another mileage datapoint 2010 FEH Limited 2WD
- HV Battery Discharging
- LED Light Retrofit
- A/C Temperature Data Point 2010 FEH
- Screaming deal on Pirelli Scorpion Verde All Season Plus II 235/70R16 tires.
- The OEM navigation radio really doesn't have an amplifier?!
- Windshield, Rain-X, and a Shout Out to Mothers
- Check Brake System/ABS Light - On/Off
- 08 feh p0128
- 08 feh p0128
- Should We Start / Does One Exist - Owner's Club?
- accelerator error when ac is on
- Siriusly remove Sirius
- Wiper Blades Replaced 2010 FEH
- Just bought 2010 Escape Hybrid with Battery Issues
- Escape Hybrid Rookie
- Finally - An actual Long Distance Mileage Test
- C1029 Uneven brake pressure
- Springtime Mileage 2010 FEH Limited Nice Day
- Coolant level question
- Interesting Video Series 2009 FEH in BAD Shape Gets Fixed Up
- Driver Door Outside Handle Sticking 2010 FEH Woes
- Updating SYNC/NAV system maps 2010 FEH Limited
- P2611 - A/C Distribution Valve
- Just what have I gotten myself into?
- Possible 2009 Purchase
- HCU brake system failure after fluid change?
- Front Wheel Bearing Replacement
- Got a P0301 Misfire code on 2009 FEH
- Spring Hybrid Speed / Mileage Fun
- DTC P0A27 with Recall (maybe) Already Performed
- Seriously, WTF?!?
- Battery Help 2008 Ford Escape Hybrid
- 16" FEH 2010 Aluminum Wheels Oxidized Treatment?
- recommendation for which year/build date FEH to buy?
- Help on charging HV battery and a 2009 surprise find
- Forscan
- Tire Recommendations - 2010 FEH 2WD
