when should battery blend door be open vs closed
Old Sep 18, 2022 | 01:16 PM
bkorbin's Avatar
2009 MMH
Default when should battery blend door be open vs closed
I have a 2009 MMH and it's easy to visually check the blend door and lately I always see it closed.
My guess is...
if the out side air and battery are cool, the blend door should be closed and fans won't run.
Once the battery warms up, blend door should open, both fans operate, and allow for out side air circulation if outside air is cool enough
If the outside air is hot, and battery is hot, the blend door closes and fans run to circulate the AC cooled air
Is this the way it's supposed to work? can anyone confirm or correct my guess.
Old Sep 21, 2022 | 05:33 AM
ShadyEscape's Avatar
Default Re: when should battery blend door be open vs closed
Makes sense. First it opens the blend door and tries fans/air. Then it closes the door and runs the a/c. Then it turns off hybrid mode if still hot. It might also depend on how fast you are going as it tries not to run the fan at low speed for noise.
08escapehybrid
Sep 25, 2023 12:29 PM
us035976
Jun 14, 2021 08:04 PM
accent2010
Sep 30, 2019 07:46 AM
gh91745
Oct 2, 2017 04:48 PM
nyceshirtz
Jul 25, 2008 11:02 AM
