09 ESCAPE Hybrid got B12A7 B12B8. Bad battery blend door actuator?
Old Sep 10, 2019 | 03:02 PM
accent2010's Avatar
Default 09 ESCAPE Hybrid got B12A7 B12B8. Bad battery blend door actuator?
Wrench light turned on several times in warm days but disappeared after restarted the engine. Found B12A7 B12B8 DTC and a P0A1F-20 DTC. Is it a Blend door actuator issue for the hybrid battery? Is it a common issues among 09? I though ford fixed it after 08. Checked a manual found B12B8 means "Driver Blend Door Actuator Slow or Door Obstructed". Wrong manual?
Old Sep 17, 2019 | 08:08 AM
Shane Carr's Avatar
Default Re: 09 ESCAPE Hybrid got B12A7 B12B8. Bad battery blend door actuator?
My 07 mariner
Old Sep 29, 2019 | 08:04 PM
accent2010's Avatar
Originally Posted by Shane Carr
The problem is I don’t know which part is broken.
Old Sep 30, 2019 | 12:53 AM
Shane Carr's Avatar
$25 dollar part. 30 min to change. Id start there. You have to reprogram bcm after install.
Old Sep 30, 2019 | 05:30 AM
Rex B's Avatar
I did not do that when I replaced mine two years ago. How do you do that?
Old Sep 30, 2019 | 07:46 AM
Shane Carr's Avatar
Forscan. Check threads.
us035976
Jun 14, 2021 08:04 PM
08hybridok
Oct 6, 2014 06:39 PM
gadgets2sell
Apr 21, 2014 05:15 PM
Tigermidge
Nov 28, 2010 10:22 AM
dgeesaman
Feb 21, 2010 04:50 AM
