wrench light but DTC is not for blend door
Old Apr 20, 2014 | 05:21 PM
gadgets2sell's Avatar
Default wrench light but DTC is not for blend door
Hi
I have a 07 FEH with 109K miles. I replaced the blend door motor last april before it failed. I had no issues until days started to get warmer then the wrench icon came on. Thinking it was the blend door I had planned to pick up another actuator from the ford dealer but decided to check the fans to be sure.
Both were operating fine and running in a variable speed depending on acceleration.
I found the settings for my scanguage to pull DTC from Bat CPU and the code
0A27 P0A27 came up. I googled this DTC and found info about a new short cable that may need to be installed in the traction battery.
I am not seeing any red triangle warnings or SSN messages only Service Soon.
I have my car registered to the my ford and there is no history listed.
Should this be something Ford will do or should I just order the cable and install?
I am a technician (not auto) and I had no issues inspecting the squirrel blowers.
MECs pump is 9 months old, and scanguage temp is reading 80's.
Chuck
Old Apr 21, 2014 | 04:19 AM
GatorJ's Avatar
Default Re: wrench light but DTC is not for blend door
You'll need to do it unless you're under extended warranty. Ford replaced this cable at no cost during a specified time period if there was a problem, but that time period has long passed. A mechanic friend and I replaced mine several months ago a a preventive measure. Contrary to the instructions, we were able to do it WITHOUT removing the HVTB from the vehicle. I have some pictures of it and a brief description of the procedure floating around somewhere. I'll provide a link this evening.
Old Apr 21, 2014 | 11:24 AM
GatorJ's Avatar
https://www.greenhybrid.com/discuss/...tml#post249666
Old Apr 21, 2014 | 05:15 PM
Well I found out from a call with Ford the update was done in 2009. So that means the code is now just ignored by the main control module, most likely from the firmware update.
I ordered a new blend door motor which I am sure (99%) will turn off the wrench.
It was 60 degrees this morning and it was out and stayed out till it warmed up later in the day.
Chuck
us035976
Jun 14, 2021 08:04 PM
gadgets2sell
May 4, 2014 03:55 PM
Sphinx88
Oct 5, 2011 01:30 PM
stevedebi
Oct 28, 2010 04:28 PM
dgeesaman
Feb 21, 2010 04:50 AM
