Blend Door Actuator - Again
Old Nov 30, 2009 | 11:29 AM
stevedebi's Avatar
Default Blend Door Actuator - Again
Last week I got a wrench light three times, always at night. The lights went out after an engine restart. I took the 2008 AWD FEH in and the dealer replaced the "Blend Door Actuator", which I believe is the part that causes the battery vent door to open. That is the 2nd time in a year it has been replaced.
SG did not report a code; the dealer invoice indicated code 1239. I expect it can only be read via the SJB.
I'm still covered by my factory warranty, and in any case if it happens within a year, a failure like this is covered by the Ford parts warranty, but I'm wondering if other people have had this issue?
Old Nov 30, 2009 | 12:01 PM
trekwars2000's Avatar
Default Re: Blend Door Actuator - Again
I might have had a similar issue as you about 6000 miles ago.
https://www.greenhybrid.com/discuss/...-needed-21583/
Old Dec 1, 2009 | 07:44 AM
Leslie K's Avatar
Unhappy Re: Blend Door Actuator - Again
I have an '07 FEH with about 42K miles (just out of warranty of course) and the orange wrench with 'Service Soon' info is appearing. It's has been coming on intermittently over the last several weeks. I took it to the Ford dealer earlier, but the orange wrench was not on at the time, and they could not get any sort of code. This morning on my way to work, it came on again and I was close enough to the dealer to take it in.
Dealer's mechanics were apparently having some difficulty diagnosing problem but eventually determined it was the "Motor Blend Door" problem that has been well documented on this forum. Anyway, to make a long story short, the dealer wants $533 to make this repair, which I think is excessive. Dealer says it's 3+ hours of labor, $35 for the part, and about $100 for the diagnostic charge.
I called another local Ford dealer and was quoted a similar price.
So what do you think??
Old Dec 1, 2009 | 08:42 AM
Just doing some match, $533-35 (cost of the part) = 498 - $100 diag fee = $398. They want $398 for 3 hours of labor? Thats $133/hour. I'd find a shop that will do repairs for $60/hour (or so). That is excessive.
Old Dec 1, 2009 | 09:13 AM
stevedebi's Avatar
Sorry, mine was covered under warranty, so the prices were zeroed out on my invoice.
Remember though that you have a 1 year warranty on Ford dealer repairs with Ford parts, so if you have the dealer replace it there is some coverage there. I mention it because mine failed within a year of being installed. If I had not been under factory warranty it would have been covered anyway.
Man, I'm hoping these things don't fail that often...
Old Dec 1, 2009 | 09:15 AM
stevedebi's Avatar
I'm not sure. Mine was marked as the "Blend Door Actuator", which to me means that it was a part that tells the motor to open the door, rather than the motor itself. But I could be wrong (wouldn't be the first time)!
Old Dec 1, 2009 | 10:33 AM
wptski's Avatar
Imported from Detroit
A thread about reading the blend door DTC with a SG-II: https://www.greenhybrid.com/discuss/...warning-18268/
Old Dec 1, 2009 | 11:05 AM
GaryG's Avatar
I've had my wrench light with a service soon message come on many times during the last 30,000 miles on my '05 FEH. Most of the time it will clear after the key switch has cycled but it has stayed on after a number of times and even a few days. It may even go a few months without a wrench light and it seems when I use heavy regen and EV driving I see it more. As long as I don't see any problems associated with the wrench light or it does not clear, I won't get it replaced or repair it myself. I have about 63,000 miles on my '05 now and it runs great except for the loss of power and gas mileage from E10.
GaryG
Old Dec 1, 2009 | 12:53 PM
Mark E Smith's Avatar
Omnia Gloria Fugit
Its not that hard to change out this motor. Warranty time from Ford is 1.1 hrs but this does not include diagnosis or reflash. All that you have to do is remove the plastic ducting where the little filter in the back goes and its right in that area. Reflash is not necessary and diagnosis is well reading the code.
Old Dec 2, 2009 | 09:46 AM
stevedebi's Avatar
Thanks, I'm going to program my SG when I get the chance. Hopefully I won't see this error any time soon!
