wrench light but DTC is not for blend door
Hi
I have a 07 FEH with 109K miles. I replaced the blend door motor last april before it failed. I had no issues until days started to get warmer then the wrench icon came on. Thinking it was the blend door I had planned to pick up another actuator from the ford dealer but decided to check the fans to be sure. Both were operating fine and running in a variable speed depending on acceleration. I found the settings for my scanguage to pull DTC from Bat CPU and the code 0A27 P0A27 came up. I googled this DTC and found info about a new short cable that may need to be installed in the traction battery. I am not seeing any red triangle warnings or SSN messages only Service Soon. I have my car registered to the my ford and there is no history listed. Should this be something Ford will do or should I just order the cable and install? I am a technician (not auto) and I had no issues inspecting the squirrel blowers. MECs pump is 9 months old, and scanguage temp is reading 80's. Chuck |
Re: wrench light but DTC is not for blend door
You'll need to do it unless you're under extended warranty. Ford replaced this cable at no cost during a specified time period if there was a problem, but that time period has long passed. A mechanic friend and I replaced mine several months ago a a preventive measure. Contrary to the instructions, we were able to do it WITHOUT removing the HVTB from the vehicle. I have some pictures of it and a brief description of the procedure floating around somewhere. I'll provide a link this evening.
Well I found out from a call with Ford the update was done in 2009. So that means the code is now just ignored by the main control module, most likely from the firmware update.
I ordered a new blend door motor which I am sure (99%) will turn off the wrench. It was 60 degrees this morning and it was out and stayed out till it warmed up later in the day. Thanks Chuck |
