2009 feh starting issues after replacing 12v.
Old Dec 28, 2022 | 07:12 PM
Matt Auer's Avatar
Default 2009 feh starting issues after replacing 12v.
Replaced 12 volt because I was occasionally having to turn ignition several times before engine would engage.
I even had to jump it a couple times though I understand that really just enable the 12v battery to engage the relay for traction battery to start engine.
regardless after putting a new 12 volt battery in problem persists.
tested voltage on 12 volt prior to engaging ignition and it was 12.85.
with ignition engaged it went to 17.5 and with engine running it jumped to 20.5. That seems too high. Is any of this normal. Could the dc relay be letting too much voltage theu to 12 v and ruining it? Where or what is the alternator like part on the car that charges the traction battery from the engine and regening? Do these go out?
Old Dec 28, 2022 | 07:41 PM
Default Re: 2009 feh starting issues after replacing 12v.
Sure it's not this?
Old Dec 29, 2022 | 07:42 PM
Matt Auer's Avatar
thank you sir!
all signs seem to point to ignition lock module being the cause!
Harvey_2009
Mar 15, 2021 08:46 AM
dirt657
General Motors Corporation
16
Oct 20, 2020 07:30 PM
acardoso
May 13, 2016 08:24 PM
b17pete
Jan 12, 2015 10:41 PM
djules
Sep 23, 2013 11:42 PM
