08 Brake pedal travel sensor failed C1524
Old Jan 10, 2022 | 08:43 PM
accent2010's Avatar
Default 08 Brake pedal travel sensor failed C1524
Have an 08 Escape Hybrid with a C1524 code. I guess the brake pedal travel sensor is bad. Is there a way to fix the sensor instead of replacing it? It's too hard to find a replacement part.
Old Jan 19, 2022 | 08:43 AM
ShadyEscape's Avatar
Default Re: 08 Brake pedal travel sensor failed C1524
Pull it out and clean the switch? See what's going on with it.
Old Jan 26, 2022 | 09:40 AM
This fellow has a video about it:
If you get the M/C from a boneyard, you can swap the sensor. He says you can't buy the sensor by itself.
You might be able to take it apart and CLEAN it internally.
Old Jan 26, 2022 | 09:47 AM
What's also interesting from that video: there is clearly a LABEL on that sensor with a couple of barcodes and other info. printed on it. The video isn't high enough resolution to adequately magnify, but I will bet that unit DOES have a part number, perhaps encoded in the barcode.
If you have a barcode reader you might be able to read the number! Anyone with a Motorcraft subscription may also be able to look it up.
I will bet it's expensive/unobtanium as a discrete unit because Ford wants you to buy the whole master cylinder. So you are looking at taking yours apart and trying to get it working or salvaging one from a boneyard.
Old Jan 26, 2022 | 10:21 AM
And Lo! The Ford part number IS available, but the part itself is disco according to this website:
https://www.fordpartsgiant.com/parts...-2c050-aa.html
Ford YL8Z-2C050-AA
Sensor Assembly2001-2012 Ford YL8Z2C050AA
You can buy it from people who have it for less than $15? If that's true it's a little miracle!
https://www.google.com/search?q=YL8Z...hrome&ie=UTF-8
Old Jan 30, 2022 | 06:23 AM
GatorJ's Avatar
Ford YL8Z-2C050-AA
Look at color pictures of that actual part number from your Google search. It does not look like the correct part.
Old Jan 30, 2022 | 09:50 AM
It may not be, you're right. I was doing my best with a quick search (I've never had to replace this part.) My main point is that from the video there is clearly a label stuck to that part with at least two barcodes on it. Maybe it is a pure internal Ford P/N not available to the general public, but you can take it apart from what I see.
Old Feb 4, 2022 | 04:39 AM
Hit the junkyard. It's probably the same as the gas escape sensor.
econoline
May 21, 2020 02:10 PM
hc45
Dec 6, 2013 04:30 PM
spiff72
Mar 1, 2007 08:11 AM
Kazdor
Mar 1, 2006 06:58 PM
