2010 FEH Limited with SSN and multiple codes - Help!
Old Sep 4, 2022 | 12:37 PM
daggerNC's Avatar
Default 2010 FEH Limited with SSN and multiple codes - Help!
My wife's FEH with 142K miles on it has been relatively trouble free. We drove from NC to MO back in June to move our daughter. That's when we got a wrench light with P0A7C code ONLY when we hit 65+mph. FEH drove fine though - every time we turned off the engine and restarted, wrench was gone and didn't come back until we got on the highway again. About 5 or 6 weeks ago, my wife told me the wrench light came on during her regular around-town routes (35 - 50mph), but no drivability issues. I used FORScan and it gave me the same P0A7C code. I checked the MECS pump (it had been replaced a few years ago) and it was running but making a louder noise than expected and so the advice was to replace it. So 2 weekends ago I changed the eCVT transmission fluid with Ford-spec ATF, and then last weekend I drained the MECS system and installed a new MECS pump (including air bleeding procedure) with Motorcraft gold coolant as per spec for my vehicle. Ran great for 5 days, but then my wife calls in a panic because her FEH all of a sudden wouldn't go more than 35 to 45 mph and had some erratic throttle response. I said, oh-oh, that is limp mode. Pull over and turn off the Escape, wait a couple of minutes and try it then. She said everything started up fine and drove home without any further issues. I connected FORScan and it pulled a bunch of codes, but none were active now. I checked everything out and reset the codes and then said lets see if it happens again. Same thing happened again yesterday - this time the stop/then restart cleared the wrench but the CEL was illuminated when she got home (no drivability issues).
Here is the list of codes in the system (plus FORScan log dump):
  • DTCs in PCM: P0A18:00-28, P0A23:00-28, P0A7C:00-28, P1A14:00-28, P2112:00-AC
  • DTCs in OBDII: P2112-C
  • DTCs in ACCM: P0AFA:16-28
  • DTCs in TCM: P1A0A-FF, P1A03-FF, P1A04-FF
What the?? I was expecting the P0A7C by itself and why I replaced the MECS pump, but now 9 other codes show (just 2 weeks ago only 1 code was in there)? I have a feeling that something triggered the vehicle to go into Limp mode which then caused a cascade of other codes to trigger...??? Is this a possibility? I am focusing on the P2112 codes as that is " Throttle Actuator 'A' Control System - Stuck Closed " and this seems to be a fairly common issue with the throttle body on Escapes/Fusions for this build-period, and would definitely cause the throttle issues and I think a SSN message/limp mode event. Should I start there/replacing the TB and this could be the reason for the other codes being thrown, or where do I start? Thank you in advance for any guidance!
FORScan log:
===PCM DTC P0A18:00-28===
Code: P0A18 - Motor Torque Sensor Circuit Range/Performance
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P0A18:00-28===
===PCM DTC P0A23:00-28===
Code: P0A23 - Generator Torque Sensor Circuit Range/Performance
Status:
===END PCM DTC P0A23:00-28===
===PCM DTC P0A7C:00-28===
Code: P0A7C - Motor Electronics Over Temperature
Status:
===END PCM DTC P0A7C:00-28===
===PCM DTC P1A14:00-28===
Code: P1A14 - Hybrid Powertrain Control Module - Transmission Disabled
Status:
===END PCM DTC P1A14:00-28===
===PCM DTC P2112:00-64===
Code: P2112 - Throttle Actuator 'A' Control System - Stuck Closed
Status:
- DTC Maturing - Intermittent at Time of Request
- Test not complete
===END PCM DTC P2112:00-64===
===OBDII DTC P2112-P===
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC P2112-P===
===APIM DTC None===
Successful DTC reading, no error codes found
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===ACCM DTC P0AFA:16-28===
Code: P0AFA - Hybrid/EV Battery System Voltage Low
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
Module: Air Conditioning Control Module
Freeze Frame #1:
-OUTDOOR_TEMPERATURE: 77 °F - Outside temperature
-POWER_MODE: Running - Power Mode Status
-AC_CIC: 1.00 A - Electric A/C Compressor Input Current
-ACCM_CHVS: 150.00 V - Electric A/C Compressor High Voltage Supply
-ACCM_ITEMP: 82 °F - Compressor Internal Power Device Temperature
-ECU_INTERNAL_TEMPERATURE: 82 °F - ECU Internal Temperature
-ACCM_ECS: 0 1/min - Electric A/C Compressor Speed
===END ACCM DTC P0AFA:16-28===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===TCM DTC P1A0A-FF===
Code: P1A0A - Immediate Shutdown Signal
Module: Transmission Control Module
===END TCM DTC P1A0A-FF===
===TCM DTC P1A03-FF===
Code: P1A03 - Drive Motor A Shutdown Circuit
===END TCM DTC P1A03-FF===
===TCM DTC P1A04-FF===
Code: P1A04 - Generator Shutdown Circuit
===END TCM DTC P1A04-FF===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===BCM DTC None===
Module: Battery Control Module
===END BCM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===IC DTC None===
Module: Instrument Cluster
===END IC DTC None===
Old Sep 5, 2022 | 06:29 AM
ShadyEscape's Avatar
Default Re: 2010 FEH Limited with SSN and multiple codes - Help!
Clean or replace the TB and make sure the mecs is actually running. Check battery hybrid voltages and a/c.
Old Sep 5, 2022 | 07:44 AM
daggerNC's Avatar
Thanks Shady - I'll R&R and clean the TB today. MECS is running, as I can hear it, feel the fluid moving in the lines, and when I bled the system, there was a strong stream coming out of the bleeder hole when I turned the MECS pump on. So check the high voltage battery pack - will look those procedures up. A/C has been working - not sure what else to do there unless it requires bringing to a shop to check pressures?
What doesn't make sense is that less than two weeks ago only had one code, and then suddenly Limp Mode and many codes....still thinking most of these were triggered by a single event??
Old Sep 6, 2022 | 07:44 AM
They do all say not present. Maybe still set from when you had the weak mecs.
Old Sep 6, 2022 | 08:48 AM
daggerNC's Avatar
Possibly. I ran the onboard system check thru the Instrument Cluster messaging display and the system came back with Hybrid battery check is OK. FEH started up OK, (noticed a little high idle fluctuations) and ICE ran for about 2 minutes and then it shut off and went into EV mode, so I'll take that as vehicle is OK with the high voltage battery/ICE charging operation... CEL is still on (triggered by the P2112 throttle body code ). New TB ordered and should be here in a couple of days. Will do the 12V battery disconnect/install new TB and MAF cleaning, and then see what happens to the codes and operation. Fingers crossed.
AlexK
May 12, 2021 05:23 PM
german_cargo
Jul 1, 2019 08:23 PM
GatorJ
Jul 17, 2018 03:10 PM
AtomicAD
Jul 25, 2014 04:35 PM
Scooters
Jun 17, 2006 08:31 PM
