PDA
View Full Version : Ford Escape Hybrid
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. 2009 air conditioner & radio question
  2. How to Silence the Engine Noise
  3. Strange sound when unlocking with remote.
  4. Brakes Pulsating / Shuddering When SOC ~ 100%, '09 FEH
  5. Crossed the "Big 100" Yesterday
  6. SOC was at 27% this morning... Because of SGII?
  7. '09 FEH Questions & Answers
  8. 2009 FEH average MPG at altitude
  9. 2008 FEH Premium Care issues
  10. Punched fuel hose to the tank - filler fuel pipe
  11. help in these parts if you please
  12. Electric air conditioner?
  13. FEH model year differences
  14. Seeking info on the battery charger
  15. battery/door actuator/smart junction box
  16. Interior lights
  17. Motorcraft Mercon LV ATF
  18. o6 trickle charge?
  19. A question concerning the FEH SecuriLock system
  20. FEH 2006 correct thermostat
  21. wrench light
  22. Anyone get a Scangauge to work on a FFH?
  23. Tailgate glass/door ajar message, how to fix it?
  24. FEH Cat Converter Plugged
  25. Front wiring harness question: what should be connected here?
  26. Anyone know if
  27. one click noise front passenger wheel FEH 2008
  28. 06 MMH available for SALVAGE
  29. HV battery pack and 12V battery discharged...how to re-charge it faster?
  30. Replacing rear wiper blade
  31. Motor Electronics Cooling System
  32. Service soon message after restart
  33. Recommended Transmission Service & Transmission Filter ?'s
  34. Transmission Dipstick on 2009 FEH
  35. Inner Tie Rods
  36. "Service Brake System"
  37. Check FUel Cap and Service emission Systems
  38. Blend Door Actuators
  39. Out With The '05 FEH
  40. Replacement tires??
  41. Service Disconnect Plug in UNLOCK Position?
  42. hybrid v nonhybrid in winter
  43. autolamp
  44. Sway Bar Link Clunking Again
  45. Newbie: Best year & reasons 05-08 FEH?
  46. Moving across continent with FEH
  47. Defroster wont start engine
  48. Bad Smell when running cabin air
  49. GForce Chip
  50. Tune-Up (100K mileage) on 2009 FEH 2.5 Ltr
  51. 2007 Navi questions
  52. Hybrid mechanic in denver area?
  53. Troubleshooting Rear Window Defroster?
  54. Brakes
  55. Switch the odometer display from KM to Miles
  56. How do I remove the engine cover plate on 2009 Ford Escape Hybrid?
  57. Residual value vs. non-hybrid
  58. Jump HV Batt?
  59. Recommended maintenance?
  60. Gas power would not engage...only Electric..until
  61. Been a while, 60K miles and nothing to report
  62. cargo liner
  63. What is the max ICE efficiency RPM?
  64. 2008 FEH Transmission acting strange
  65. 1st Person Experience with depleting the 12v battery
  66. Bought 2009 FEH - Have 2 questions
  67. Mec
  68. Can I plug in my FEH?
  69. $5+/gal gas
  70. Trailer Hitch Wiring?
  71. NAV system for 08 FEH
  72. Rough idle @ startup for a few seconds
  73. DIY Brake Job
  74. Water stains on 2009 seats
  75. 18F Tav drop while at work
  76. 07' ford escape hybrid 4whl drive load "clunk" from rear when put into reverse
  77. Regen Question
  78. New smaller Ford SUV coming
  79. Signal wire
  80. Electrical Anomaly on Start
  81. Considering USED FEH - what to watch for?
  82. Ford Escape 2007 Navteq map updates?
  83. Rear Window Spontaneously shatters
  84. Highest Mile Escape
  85. ScanGauge SOC =92; Amps =104 !!!!!
  86. Should I even bother with a hybrid??
  87. Battery heater
  88. 08 FEH - 3 weeks of ownership, but questions remain
  89. RWD..4WD 2012 Escape.
  90. 2009 Ford Escape Hybrid Dead at -2degF
  91. no light on my motorcraft battery
  92. Squeak or chirp in 2008 MMH center console
  93. Type of gas used
  94. When should I change the oil on my 2006 MMH?
  95. Blizzaks on the Front?
  96. 06 FEH Evap System Leak detected
  97. Dramatic MPG drop recently, common causes?
  98. Noisy battery fan
  99. hybrid enhancer?
  100. Next Generation Escape at Detroit Auto Show
  101. Block heater, coolant heater
  102. My Sync and ipod don't work for 2nd time.
  103. FEH-09 Passed my initial expectations.......
  104. Jump Start FEH 2005 - Please Help!!!
  105. What should I expect??
  106. Winter Tire Set Questions
  107. Tire size & spare questions
  108. 2008 Ford Escape Hybrid Won't start just lots of clicking & flashing lights
  109. 2006 Escape hybrid, thoughts on if I should buy
  110. Scangauge Ammeter
  111. Anyone with factory NAV/Hybrid display able to get the Fuel Econ readout in cluster?
  112. 2009 Ford Escape Hybrid 50,000 mile report with pictures and movies. LONG!
  113. Found a good ethanol mix???
  114. Recall 07B48
  115. First Hybrid FEH '05 or '09
  116. Senate Approves Noisemaker Law For Hybrids / EVs
  117. SOC limit lower after oil change
  118. Win a Sony Playstation 3 (PS3) or Gran Turismo 5
  119. Fuel filter. where is it?
  120. Ford Escape Hybrid 4WD just spins on snow and ice
  121. Class III receiver issues
  122. yellow wrench light on
  123. Enginer bttery kit
  124. Mileage in winter
  125. Scan Tool for FEH wrench light
  126. Escape Airbag Malfunction
  127. Lincoln Escape
  128. Electrical short in brakes? Or bad 12V battery?
  129. Low Roll Resistant Tires & Rims
  130. Educable engine for MPG
  131. Need Stop Safely Now Insight
  132. Crazy Thing Happen Today
  133. Nitto Tire on Facebook, LIKE to win tires
  134. Block heater
  135. Engine off - noise from engine compartment
  136. Engine soundproofing
  137. Hybrid battery warmer for 2009+
  138. Newbie question!
  139. 08FEH Dealership Service Troubles
  140. FEH 2005 - Black oily soot in exhaust & Brake propblem
  141. Extended Warranty
  142. air conditioner problem
  143. Gentex Rearview Mirror/Camera
  144. Repl tires other than Michelin or Continental
  145. MECS fail warning?
  146. Replaced my tone ring - shop notes.
  147. Sync Microphone kit TSB
  148. Battery Push Button
  149. Spun Bearings & Such
  150. Michelin Tours VS Eco-Plus
  151. Newbie question: Best practices for driving
  152. 2006 Escape Hybrid, driver door lock doesnt unlock after batter replaced
  153. Does PA have the extended 150K mile battery pack warranty on FEHs??
  154. Cabin air filter for 2008 FEH
  155. How long do codes last after coming on?
  156. Nervous about buying a hybrid escape -- HELP PLEASE!
  157. Engine failure: Replace or rebuild
  158. Garmin EcoRoute HD
  159. Tone ring replacement and other things found
  160. A/C problem appears to my ford escape 2005
  161. No more hot battery, cabin air cools it.
  162. Rear A/c problem, hot battery.
  163. Service Brake System warning ???
  164. Can't find info on clearing blend door code.
  165. Service Engine Soon
  166. 911 Assist
  167. External Security Keypad Replacement
  168. Failed Pollution Element
  169. Sudden short loss of power, car skips/stutters
  170. Second Failure on my 09 FEH
  171. Front Brakes - Regen disabled alert on '07 FEH
  172. 2005 FEH sevice manuals
  173. The PTU Fuse Drill
  174. BACK...To the FUTURE...
  175. 100K Service Recommendations?
  176. 17 inch 3680 chromes on 08 Escape Hybrid
  177. Problem with A/C and HV Battery
  178. What is this part, and why is it crying?
  179. '09 FEH MPG Techiques
  180. Laditude Tours on a 2005 Escape Hybrid??
  181. Whell lockup during braking
  182. Prius gets sound option to protect pedestrians
  183. NAV system for 2008 FEH
  184. 26 mpg?
  185. Joined the club
  186. A/C cooling problem
  187. when electric switches to gas does yours do this?
  188. 2009 FEH Navigation Radio upgrade to HD
  189. Wrench Light
  190. can you diagnose CAUSE of red triangle with SG2?
  191. Need new front brakes at 38,000 miles
  192. '09 FEH - 62.329mpg Tank
  193. 2011 Explorer get PTO/PTU cooling.
  194. 2009 Escape Hybrid Climate control problem
  195. Pulling the PTU Fuse
  196. coolant color question for 2006 mmh (tough question )
  197. 2008 FEH towing capacity
  198. Dead low voltage battery
  199. HV Battery Self-discharge Rate
  200. OK...heres a good ?....ford escape VS mercury mariner HYBRIDS
  201. Vehicle differences between States
  202. TPMS question
  203. Battery "Saver" / auto acc off...
  204. Deteriorating MPG
  205. High pitch noise while braking?
  206. MMH dead?!?!?!? please help ...what to do? jump?
  207. Engine Braking
  208. Vibration at 2000rpm - 2009 FEH
  209. 2011 escape
  210. what are the factory spark plugs in 06 hybrids?
  211. Service soon light came on (now gone) What it mean
  212. Found out there was no filter for the battery!!
  213. FEH battery in a Honda Insight?
  214. would anyone be willing to run a carfax report for me? not the autocheck one...
  215. why the ford escape is worth more than the "upscale" mercury mariner???
  216. Rear Air Conditioning Line Failure - Parts Shortage
  217. 12V battery died???? And then brakes didn't work right???
  218. Selling FEH
  219. Battery Cooling Fan Failure: Warranty or Not?
  220. Would you buy a escape/mariner hybrid with 127k on clock (2006 year)
  221. "Stop Safely Now" when engine should kick in 07 FEH
  222. BIG News out of Ford
  223. how will i know when the battery is getting weak and near death???
  224. Rear Ended And Now Transmission Noise
  225. 2005 vs. 2007 Escape hybrid mileage
  226. Question on Tires for FEH
  227. New Problem - Clunk and ABS lite flash just before stop
  228. Clicking / Popping sound when starting and stopping
  229. FYI: Cabin Air Filter
  230. The Brakes Broke the Bank!
  231. Battery Replacement
  232. Engine Oil Jaw Drop
  233. Whine / groan coming from cargo area
  234. HID Retrofit
  235. Troubling Noise from Under Hood
  236. Just finished cross country trip
  237. Weatherstrip on drivers door - Replace
  238. Video - Warm-Up P&G
  239. Just Got a ScanGuage - Set Up?
  240. 2007 Shop Manuals
  241. No Start - Dead - Batt(s)?
  242. FEH Not selling?
  243. Drive shaft coupling bolts
  244. 2010 FEH 4x4 in the shop
  245. Went to change cabin air filter and ended up...
  246. Repair history
  247. Radio RDS won't show on dash display? FEH 2009
  248. Replacing Front Brake Pads
  249. Oil change
  250. Enhancing (hacking) performance of the FEH EV battery?
