Block heater
Old Oct 30, 2010 | 11:19 AM
colchiro's Avatar
Default Block heater
What are you guys doing to make block heater connections easy?
I always have to struggle and wiggle the connector to plug/unplug mine, it's never an easy connection. I considered cleaning the plug prongs, but haven't yet and can't think of a lubricant that's safe and effective. I suspect it'd be a lot easier if the heater cord was firmly attached to the body like EV's. It doesn't help when there's water running off the hood or water in the plug cap either. I hate winter.
Old Oct 30, 2010 | 01:28 PM
wptski's Avatar
Imported from Detroit
Default Re: Block heater
Use dielectric grease which can be purchased at any auto parts store. I know that CRC brand has some. I'm sure that any Ford Dealer has some also for more money.
Here's the Ford brand listed in the manual for use on the COP's: Motorcraft-XG3A
Old Oct 30, 2010 | 04:41 PM
colchiro's Avatar
Thanks Bill.
Has anyone tried this?
I guess they have: http://www.delica.ca/forum/dielectric-grease-9338.html
Old Oct 30, 2010 | 05:35 PM
wptski's Avatar
You can also use NyloGel 759G which was used on automotive connectors till it was replaced by NyloGel 756G which has a higher temperature rating. I use the 759G on battery contacts to prevent corroding. The 759G is real easy to find. I bought a couple of tubes, so I'm good for life.
You can go to:http://www.nyelubricants.com/ for specs and MSD's.
Old Oct 30, 2010 | 05:58 PM
colchiro's Avatar
Found a pocket pack at my neighborhood auto parts for about a buck. Cleaned the terminals and added a bit and it seems to be better.
Thanks for the idea.
Old Nov 3, 2010 | 05:54 PM
Note that dielectric grease is just that: dielectric. IOW it doesn't conduct electricity. So don't use it on the prongs of the plug.
Old Nov 3, 2010 | 08:31 PM
wptski's Avatar
That's funny as here's some from Permatex: http://www.oreillyauto.com/site/c/de...0941&ppt=C0139.
Can't say if they still do but Ford used dielectric grease on their injector connectors but not other connectors.
Here's a direct link to the Nye Lubericants that I mentioned above: Conductive Greases
Old Nov 4, 2010 | 12:31 PM
EVDRVR2's Avatar
I use GB OX/Guard on the connection to the charge port on My EV. As it is a conductive paste it is designed to improve conductivity and reduce heating on wiring. Especially Al. As it is also greasy it makes the plug slide and lock very easily. I just put a little in the receptical and it does a great job. Have not had to reapply it in over 4 years.
Have also used it in the house on a few wall sockets that seem to grip plugs a bit tighter than necessary.
Only down side I have found is it is black and if you get it on things it shows. Cleans off pretty easily.
Old Nov 4, 2010 | 07:35 PM
Dielectric grease
This grease is used on connectors to ensure a weather seal & to ensure that, for spark plugs, high voltage & current doesn't leak past the boot. But it's not there to enhance conductivity.
My point is not about the boot & weather seal but about the conductive contacts. A dielectric is by its nature highly non-conductive, so don't put it on the prongs of the plug.
'Nuff said.
Old Nov 4, 2010 | 07:38 PM
Follow the oreilly link above, read the description, and you'll see that the permatex product is about sealing boots around connectors, not about enhancing the conductivity of the electrical contacts.
