17 inch 3680 chromes on 08 Escape Hybrid
Old Aug 29, 2010 | 07:03 AM
miamitennis's Avatar
Default 17 inch 3680 chromes on 08 Escape Hybrid
Hi
I want to replace the 16 inch wheels with the 17 chrome 3680 wheel. Has anyone tried this?
Old Aug 29, 2010 | 04:11 PM
GaryG's Avatar
Default Re: 17 inch 3680 chromes on 08 Escape Hybrid
Originally Posted by miamitennis
Hi
The rims on the '08 are special lightweight rims for lower roll resistance. Steel rims are heavy and generally have problems being more out of round than the painted aluminum rims on your FEH. I have factory steel rims on my '02 Explorer and they have convinced me to never use steel rims again. The tire store told me all my steel rims were out of round and they find this all the time with steel rims.
If you get the steel rims, make sure they're good and round. Expect a MPG hit if they're heavier than the stock rim and tires. If the diameter is not the same as the factory tires and rims, you may need to have your PCM programmed for the changed to match wheel rotation with the other sensors in the eCVT. You can get a trouble code if the shaft rotations are to far off with the wheel rotations.
GaryG
Smoothieking
Toyota Highlander Hybrid
Sep 13, 2009 10:01 AM
cenozoic
May 3, 2009 07:58 PM
happydad1971
Feb 25, 2009 04:17 PM
ftlum
Apr 23, 2006 11:23 AM
Doozer
Sep 28, 2005 10:14 AM
