PDA
View Full Version : Ford Escape Hybrid
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16
  1. Unravelling Engine Braking - pre-'09 and post-'08
  2. Blend Door Repair and Scan Gauge
  3. Goodby to my FEH!
  4. CV Half Shaft
  5. Engine doesn't shut off when stopped
  6. Finally Got Awesome Mileage!
  7. Just bought first hybrid 06 AWD FEH
  8. scan gauge for towing and what temps you can read.
  9. FEH A/C performance in hot weather
  10. Trailer, Towing, Battery and Inverter output.
  11. Vibration and shudder on startup
  12. Adding a sub and amp?
  13. Key hard in insert
  14. braking problem --- scary
  15. 100k maintenance
  16. 2005 w/code 9239
  17. I think my MECS finaly died :(
  18. 2008 escape hybrid awd, possible bad rack and pinion
  19. 06 MMH with clunk at ~1800 RPM
  20. 05 FEH getting SSN message with lots of codes
  21. not feeling the difference b/w D & L? try this
  22. OBD Scan Tool
  23. Best Chicago area Ford dealer for end of warranty inspection
  24. Escape hybrid hesitation at low-speed
  25. upgrading stock stereo to touchscreen stock possible? & other new questions.
  26. 280 hp FEH
  27. service, tune up
  28. Escape 2006 not going into hybrid mode
  29. 08 feh towing, the road so far
  30. Anyone want an X3-FRDW AUX input interface for their CD changer?
  31. TSB 09-18-6 and the CSB 07B48 Conundrum...
  32. Please help. PCV hose tear 06 feh
  33. Youtube - Taxi Battery Teardown
  34. Coincidence or Correlation???
  35. help buying a 2007 escape hybrid- first time buyer
  36. Need advice!! might buy 07 escape hybid
  37. Help please to locate and change coolant sensor on 2008 Ford Escape Hybrid??
  38. turbo atkinson cycle engine
  39. 2006 FEH Decreased Braking regen
  40. Ford Recalls 900K Escapes / Mariner 2008-2011
  41. Converting non-Hybrid Escapes
  42. P2010 code - Stop safely now?
  43. Rounded Head in Oil Filter Cover Filter Cap Drain Plug
  44. rev and mph
  45. ecvt cooler
  46. steering click noise
  47. Leaking Sunroof - Help Needed
  48. Check Brake System
  49. AC not cooling / Wrench light issue
  50. Help!!! Escape leaking yellow fluid from driverside rear?
  51. service soon yellow wrench
  52. 2010+ FEH Known Issues?
  53. Fuel Rail Pressure problem
  54. MECS 'Stop Safely Now' trigger temp
  55. wrench light but DTC is not for blend door
  56. What's your favorite mod on a 2008 FEH?
  57. Recommended Trailer Hitch
  58. ford escape hybrid 2006 PTU
  59. Rear Wheel Regen using AWD
  60. Vehicle won't turn over
  61. Looking for an 08 or newer Escape 4WD - have questions.
  62. CVT Transmission
  63. New rear shocks - piece of cake.
  64. Handbrake issue
  65. Putting 2006 FEH HV battery In service mode
  66. AIT Air intake temperture sensor
  67. 2006 ford escape hybrid 2wd disable brake system
  68. engine temp
  69. Rattle from engine bay at idle
  70. EV Mode Question
  71. Another Stealership rip-off
  72. Looking to purchase 08 FEH FWD. Have a few questions.
  73. newbie needs help with getting the most from vehicle
  74. 2007 Ford Escape Hybrid and non-Hybrid Engine differences
  75. 2009 Escape MECS part number
  76. VW style flip key from Ebay
  77. 2006 Escape HYBRID DIY friendly?
  78. 2006 escape FEH with 150,000mi
  79. Just bought an 08 Escape
  80. Replacing suspension bushings in 2006 FEH
  81. Service Manuals
  82. Bluetooth OBDII Diagnostic Scanner
  83. Shocks and Struts 2008 FEH
  84. 6yrs and 188,000mi, HVTB time?
  85. Help escape won't turn off
  86. Front end noise?
  87. 2007 FEH Factory/Dealer Alarm actuates for no reason
  88. Advice on purchasing used FEH. Take to Ford?
  89. FEH '06 - Battery discharge after a day or two
  90. 2008 Escape Hybrid 3 star driver side crash rating?
  91. ABS and Brake warnings, but good brake power???
  92. Need to step on gas to start car? 2008 FEH
  93. Front Stabilizers
  94. Are FEH dipsticks Accurate?
  95. EV->ICE restart temp question
  96. EHCU Bleed procedure
  97. Caliper changeout w/o EHCU bleed
  98. Thank you Very Much
  99. Must turn key multiple times
  100. Yellow wrench and stop safely now
  101. ABS Buttonology
  102. 08 FEH Brake Fluid "Puddle"
  103. 2006 FEH w/stop safely now
  104. 2008 FEH: Sell, Trade In, or Keep
  105. '05 FEH acting weird again
  106. 2006 Nav Radio issue! Any ideas?
  107. 2013 C-Max Energi
  108. 4WD Escape Hybrid 2008
  109. Mileage Drop - from 34+ to 30 - 31
  110. Thinking about selling my truck in the spring
  111. vibration at hi-way speeds
  112. Scangauage upgrade?
  113. Help! '08 Escape Hybrid says "Check Brake System" on initializing cold start, why?
  114. 06 FEH 109K miles, need advice
  115. Replacing brakes on a 2006 FEH?
  116. wrench in dash keeps coming on i 05 FEH
  117. Its that time of the year again...
  118. MECS Pump Lifetime
  119. Power Steering Failure
  120. Towing Enclosed trailer 2010 Escape Hybrid
  121. Engine water pump
  122. "Energy flow function" and "Fuel economy function" buttons not working
  123. Radiator fans on all the time
  124. just replaced battery under the hood in 05' Feh
  125. Intermittent fueling problem
  126. 100,000 miles on FEH Tires
  127. Loss of Power in Left Turn
  128. 2006 Escape Dies While Driving
  129. used 06 feh question
  130. TPMS-is it necessary?
  131. System Check doesn't detect Bad Brake Light
  132. Looking for a grid charge in Atlanta area
  133. Purchase Advise for 06 (1 Owner, Government)
  134. Weird thump at engine shutdown
  135. TPMS Sensor Training Tool Battery Replacement?
  136. Normal thermostat operation
  137. Good discount for Scangauge shoppers
  138. MEC temps
  139. Hybrid Newb!
  140. Bypass Tube
  141. Ford Escape Hybrid Navigation Radio not working
  142. SJB Smart Junction Box_ Tire Sensor Failed
  143. Just picked up a new to me '05 FEH
  144. Where to get two small misc. FEH parts
  145. 2005 Escape Hybrid CVT Issue
  146. FEH speaker or tweeter?
  147. engine makes a little noise when accelerating_FEH
  148. '08 Escape Hybrid needs rotors and pads soon--Any advice please? Brands?
  149. NO is charging 12 volt battery.
  150. Need an instructional for climate control actuator replacement
  151. Killed my 12v battery last night (2005 Ford Escape HEV) and have questions after jump
  152. Dying 12V battery or something else? [Service Brake Sytem error]
  153. Atkinson cycle
  154. 2006 Ford Escape Hybrid 2WD
  155. Weld Muffler
  156. 2005 FEH wont start after 15 days with no use HELP!!!
  157. Tire Monitor Fault _FEH '07
  158. Abs light randomly coming on
  159. scangauge Xgauge for tank MPG
  160. PTU vent tube had just about fallen out!
  161. Scangauge daisy chain cable
  162. '07 not turning to electrical mode
  163. Replaced the 12v Battery Today
  164. 2006 Ford Escape Hybrid Brake Hose Failure
  165. Rear differential must not hold 2.96 pints!
  166. C-Max Energy
  167. Extend your ESP warranty
  168. Escape Turned off
  169. replacement GPS antenna
  170. Latest on my FEH's
  171. 2008 FEH Starting Issues
  172. Wiring a DashCam - Need Advice
  173. 2008 FEH 500,000 miles
  174. Experienced my 1st 'battery conditioning'
  175. Check Engine Light - P1450 Excessive Vacuum
  176. Tie rod linkage on 2006 AWD FEH
  177. escape hybrid in sweden
  178. One tire punctured, have to replace all?
  179. What shoud I get??????????
  180. Hydraulic Control Unit
  181. 2008 Ford Escape Hybrid wont crank, wont start, no anti-theft light
  182. Michelin or Bridgestone?
  183. Bought a used FEH 2006
  184. Stop Safely? It won't even start!
  185. Diminished Value Claim
  186. Sold My '09 FEH
  187. 2005 Escape Hybrid A/C Orifice Tube
  188. Humerous
  189. battery overheat?
  190. 2005 FEH: Service Power Steering
  191. HV Battery Not Cooling - Need Help
  192. Occasinal no start 08 gen1
  193. HV battery fans question
  194. electric throttle body
  195. Letter from law group- stop safely now
  196. A/C Issue
  197. 2007 FEH pull over immediately
  198. Life Span of Hybrid Cars?
  199. DIY-Does anyone change Rear Brakes-2009 Ford Escape Hybrid
  200. Dead 05 FEH - Need Help
  201. Replacement of Aux. Coolant Pump?
  202. Already rusting badly on rear quarter panels
  203. 2006 Escape, no motor (ac/pump?) runs at initial startup
  204. Thermostat Stuck Open?
  205. '05 HV battery temp vs able to go EV
  206. New FEH Owner - w/ just a few problems.
  207. Aftermarket Wiring Harnes Stereo Install NAV/Sub System
  208. Turning on MPG display after NAV removal
  209. Front click when stop and start
  210. 06' FEH Dead and Gone.
  211. GREAT Deal On MOTORCRAFT FL2017B Cartridge Oil Filters.
  212. Factory radio fun
  213. C-Max Hybrid = 2013 Escape Hybrid ?
  214. Brake job time!
  215. DTC P0562 Keeps popping up on OBDII
  216. Just bought an '05 escape
  217. FEH 2006 Rattling Higher Speeds
  218. Ford Escape off-road deep sand driving
  219. Ford Escape
  220. Escape 110-volt power outlet - camping usage
  221. Flat towing FEH with an RV
  222. MPG (Engine?) Problem
  223. tpns
  224. Man Steals Taxi At SFSU And Leads Police On High-Speed Chase
  225. Black plastic containter behind driver fog light?
  226. Rear ended (lightly)
  227. replacement battery in 05 FEH?
  228. Possible to remove center console on '05 FEH?
  229. Dealer Buyback?
  230. having engine compartment detailed
  231. 200,000 Today
  232. Video: How to replace spark plugs Ford Escape Hybrid
  233. Computer hacks??
  234. Used 2008 Escape Hybrid: 4wd vs. FWD
  235. 2008 Rear End Rattle Fixed
  236. in my 05' FEH.
  237. Installing Pioneer double din radio in my '05 FEH
  238. Potential purchase - 2006 FEH
  239. Strut to Steering Knuckle bolts
  240. Vehicle health report - other countries
  241. Replace brakes?
  242. New FEH owner with some questions
  243. "New" Mercury Mariner owner
  244. Research on Hybrid Battery Life
  245. What's an '08 worth ?
  246. 2006 Escape w/150,000mi ?
  247. Has anyone's transmission mechanically failed?
  248. '05 feh - will disconnecting battery cause any problems
  249. 05 FEH Needs Brake Pads/Rotors but instead has Dead Battery
  250. Not getting any assist when cold, hardly any when warmed up.
