Ford Escape off-road deep sand driving
Old Apr 22, 2013 | 02:50 PM
steefozo's Avatar
Default Ford Escape off-road deep sand driving
I've been driving my Ford Escape hybrid 2009 (4WD) for a while so far and I really still enjoy riding that vehicle .... During the past month I visited Rum Valley (Jordan) many times , and this valley is a real desert with deep dry sand , my Ford 4 wheel drive performance was amazing , and wheels never spines , but I noticed though that it reaches a limit where I loose engine power completely , like if I try to drive a very deep sand , and I push on gas pedal to the end but the engine stops responding and its like if the car is telling me that it can not go further on this sand - way (but what can I see that its possible to go further ) ,,, the question is how to go further to the maximum limits ... Any ideas on this part guys ....
Old Apr 22, 2013 | 03:36 PM
GaryG's Avatar
Default Re: Ford Escape off-road deep sand driving
Possible your traction control is kicking in.
GaryG
Old Apr 23, 2013 | 04:49 AM
steefozo's Avatar
After checking car manual , I found that GaryG comment is correct : its the traction control system that prevents wheels to spin by reducing engine power , this can be disabled by Turing off the RSS switch on Escape 2009 models and later ..
Old Apr 26, 2013 | 07:41 AM
wwest's Avatar
Some Escapes have a system that was used to detect overheating of the AWD rear drive clutch and would actually disable it fully if it overheated. That would leave you with front drive only making it highly probable that wheelspin would result each and every time you give it gas and you gte TC activation.
But thee should be an icon lit up advising you of same.
Old Apr 26, 2013 | 07:47 AM
wwest's Avatar
You can disable TC by pulling the ABS fuse. But then you should excersize greater constrain on the throttling level since you now have an indication that the AWD system was being overstressed.
Hope that helps.
Jefferson
May 15, 2009 10:51 AM
georgelawrence
Toyota Highlander Hybrid
Apr 22, 2007 11:45 AM
Chilly
Aug 28, 2006 02:55 PM
Orcrone
Aug 11, 2006 06:11 AM
azgirl
Apr 20, 2006 11:11 PM
