Escape 2006 not going into hybrid mode
Old Jul 1, 2014 | 07:05 PM
Hybrid2006's Avatar
2006 4WD ESCAPE FEH 140k
Default Escape 2006 not going into hybrid mode
I have a 2006 escape hybrid that is not charging the batteries when braking. (The gauge won't move). The truck is acting normal otherwise. Any ideas?
It won't go into hybrid mode
Old Jul 2, 2014 | 04:42 AM
us035976's Avatar
Default Re: Escape 2006 not going into hybrid mode
Where do you live? How hot has it been lately? Is the A/C working normally? If the HV battery gets above a certain temperature it will not accept any more charge to protect the battery.
Old Jul 2, 2014 | 06:24 AM
Hybrid2006's Avatar
I actually have noticed that the AC is not as cold as it used to be. I have had it looked at recently and was told that I have the correct amount of Freon and everything looks correct. The dashboard indicators say that everything is fine and that the charging system is fine. I am in New York and it has been warm. Do you have any suggestions if the air-conditioning seems to be operating like it should? I was hoping I was just low on refrigerant and get a recharge and everything would be fine
Old Jul 2, 2014 | 05:45 PM
us035976's Avatar
What several users here (including me) will tell any Escape or Mariner Hybrid driver is to get a ScanGaugeII. (ad at the top of this website) You can program it to monitor the critical systems of your hybrid. With info from the Scangauge you can tell if your HV battery is too warm among other parameters that affect your hybrid performance and mileage. Otherwise it's usually a guess as to what is wrong. I have been able to diagnose several of the common problems seen with the FEH and with links available here and elsewhere fix most of them myself for WAY less than the dealership would charge.
Old Jul 3, 2014 | 08:21 AM
Hybrid2006's Avatar
Thank you for the replies Rich. the air-conditioning not being cold enough is affecting everything. I will look into other ac components to see why it's not cold even though the refrigerant is full. I will also look into that scanner. Thx
uwviper
Sep 6, 2012 05:58 AM
jm85
Aug 22, 2012 09:10 AM
C11634
Dec 24, 2006 11:08 AM
bwilson4web
Jul 21, 2006 12:40 PM
