2006 ford escape hybrid 2wd disable brake system
Old Mar 22, 2014 | 04:36 PM
xraymarc's Avatar
Default 2006 ford escape hybrid 2wd disable brake system
I have a 2006 FEH 2WD with 150,000 mikes. The front suspension is shot and my driver's side wheel bearing is starting to go. I do not want to bring it to the dealer because he wants to charge me 1100 dollars for a new wheel bearing and inner and outer tie rod ends. I would bring it to a regular mechanic but I want to make sure I tell them the right way to disable the regenerative braking system. I believe you remove the two fuses in the junction box and disconnect the battery; then you are good to remove the calibers. Does this sound correct?
Old Mar 23, 2014 | 10:25 AM
us035976's Avatar
Default Re: 2006 ford escape hybrid 2wd disable brake system
From what I can see posts #9 & #10 in this thread covers what to do.
https://www.greenhybrid.com/discuss/...ke-pads-24669/
Good Luck.
Old Mar 23, 2014 | 07:48 PM
GeorgiaHybrid's Avatar
Forgive me for being stupid guys but doesn't the brake pressurization just pressurize the brake accumulator? I don't think the calipers are pressurized unless someone presses on the brake pedal.
I will admit that I am more familiar with Toyota's but I have never pulled any fuses when putting front brake pads on a hybrid car.
Old Mar 27, 2014 | 08:41 PM
nitramjr's Avatar
You are probably correct and you don't have to remove the fuses but why take chances? When I did the brakes on both of my Escapes, I removed both fuses AND disconnected the 12V battery. I waited until after the brake system depressurized before doing any of the above. Again, probably overkill but I certainly wasn't going to take any chances. I followed the procedure from the service manual and it went very well.
xraymarc
Aug 8, 2013 03:58 PM
tya2agt
Oct 9, 2008 08:08 PM
08FEH
May 10, 2008 06:46 AM
Morocco
May 9, 2007 08:20 PM
ericbecky
Website Questions & Input
May 19, 2005 02:28 PM
