2006 Ford Escape Hybrid 2WD
Old Aug 7, 2013 | 08:22 AM
xraymarc's Avatar
Default 2006 Ford Escape Hybrid 2WD
My 2006 FEH driver side break hose broke last week with a 135k. I drove the car to my dealer and he said the hose needed to be replaced and I should consider replacing all the brake hoses because they show signs of aging. After changing all 4 hoses, the dealer could not bleed the brakes with the ids system. At the end of every bleed, he got the error message that their is a bleeder valve open. In reality the valve was closed. The mechanic called fords tech line which told him to bleed the system multiple times and then if that does not work, try a manual bleed. Well , he did all that to no avail. Ford said I need a new hcu unit. I have a ? Has anyone heard of the bleed valve error and can I put in a used hcu. I found one from a car with 64000 miles on it and the dealer tells me 6 hrs of labor to install. In the most recent iteration of the part did for fix the premature failure of hcu. I found one from a 2007 which has same hcu number listed.
Old Aug 7, 2013 | 09:20 PM
go-part's Avatar
Former Vendor
Old Aug 8, 2013 | 03:58 PM
Billyk24's Avatar
Default Re: 2006 Ford Escape Hybrid 2WD
Before spending any money have the dealership print out the exact code numbers and the peanut gallery found here can proceed. I suspect it is not what you have been told.
xraymarc
Mar 27, 2014 08:41 PM
tya2agt
Oct 9, 2008 08:08 PM
08FEH
May 10, 2008 06:46 AM
Morocco
May 9, 2007 08:20 PM
ericbecky
Website Questions & Input
May 19, 2005 02:28 PM
