ABS Buttonology
Old Jan 11, 2014 | 06:59 AM
Default ABS Buttonology
I have an ABS light. How do you retrieve the DTCs from the ABS? Using the regular readout button pushing shows no stored DTCs.
What buttons and sequence do you push to get this info?
Old Jan 11, 2014 | 04:26 PM
GeorgiaHybrid's Avatar
Default Re: ABS Buttonology
You need a good scanner to retrieve those codes.
Old Jan 12, 2014 | 08:01 AM
Billyk24's Avatar
Does the ABS light come on during braking? Then it could be the famous cracked tone ring.
Old Jan 15, 2014 | 04:05 AM
No, brake line broke. Replacing calipers and such so want to ensure I know all that's in the stored DTC memory.
Old Jan 15, 2014 | 02:28 PM
Bill,
You will need a factory scanner or a good aftermarket (I use Snap-on's). There are also some ABS only scanner units out there but they are pricey as well.
highlanderhybrid
Toyota Highlander Hybrid
May 14, 2007 12:02 PM
Chilly
Apr 16, 2007 11:02 PM
highlanderhybrid
Feb 15, 2007 06:40 PM
kmh3
Sep 16, 2005 03:30 AM
zx24szq
Aug 9, 2005 07:53 PM
