ABS Silonoid
Old Apr 9, 2007 | 08:49 AM
Chilly's Avatar
Default ABS Silonoid
Anybody else have problems with the ABS actuator making a clunk/clicking noise when stopped at a red light. About every 25-30 seconds you get a short clunk. Almost sounds like a bad relay.
Only happens when you foot is depressing the brake at a complete stop.
Old Apr 9, 2007 | 06:30 PM
highlanderhybrid's Avatar
Default Re: ABS Silonoid
That light buzzing kind of noise? My Highlander Hybrid does it and my Prius did too, it's just recharging the brake system from what I was told, its normal. Just one of those awsome Hybrid sounds.
Old Apr 9, 2007 | 08:40 PM
Chilly's Avatar
Default Re: ABS Solenoid (corrected spelling)
Nope. This isn't the buzz. It is heavy Thunk that happens about every 20-30 seconds when stopped and your foot is on the brake pedal. Doesn't happen during braking, but when stopped.
Had the dealer look at it today and he thinks the actuator needs to be replaced. I guess there is a TSB out on the Prius for a similar noise related to air in the actuator.
Old Apr 16, 2007 | 07:26 PM
Chilly's Avatar
Quick Follow up. The HiHy went in last Friday and the ABS actuator was replaced. Thank god it was under warranty because this was 2000 part.
Talked to the tech some more about the issue and they believe that there may be a design flaw in the brake lines that is allowing air into the actuator that then causes the noise. There is supposedly a TSB out on the Prius for this issue. Right now there only solution was to replace the actuator, but there is no guarantee it won't return.
For now the noise is gone, so let's hope it is fixed permanently.
Old Apr 16, 2007 | 11:02 PM
tomdavie's Avatar
no more oil
No
We never had that issue. But we will keep it in mind.
biglinda
Jul 18, 2017 01:18 PM
highlanderhybrid
Toyota Highlander Hybrid
May 14, 2007 12:02 PM
highlanderhybrid
Feb 15, 2007 06:40 PM
kmh3
Sep 16, 2005 03:30 AM
zx24szq
Aug 9, 2005 07:53 PM
