View Full Version : Ford Escape Hybrid
Pages :
5]
13
16
- 09' Escape Hybrid Heat problem
- Intermittent cabin heat when in EV
- HELP FAST: How to tell is a used hybird has the 10yr/150,000 mile warranty?
- Trade in 09 FEH for Edge, thoughts?
- How many radiators should 06 FEH have?
- Torque Converter operation.
- Changing Coolants?
- Loss of heat while in EV mode
- Hcu
- Rearview camera systems
- Oem stereo to Sat radio car audio
- ICE turns off when coolant reaches what temp?
- Question about item in the Scheduled Maintenance Guide
- 2010 FEH Parking lights won't go all the way off
- MECS pump, aftermarket or OEM?
- Ford Sued over Fusion, C-Max Mileage Claims
- Stop Safely Now - P0405 Code
- 2009 Escape Hybrid engine light
- Weird ICE/EV behavior today
- Replace two tires or four?
- Very cold in Siberia
- Noob Mariner Owner questions...
- Cabin Heater Pump - Part?
- Blower motor went out but started again after restarting at night
- '09 FEH Parked 1 1/2 Years
- FEH air rear conditioner problem
- SSN on cold engine
- Technical Service Bulletin ASI-22242
- A/C not keeping engine on?
- 2006 FEH Groaning When Steering Low Speeds.
- Reattaching bumper cover
- ICE not turning off in the cold
- Highest speed in EV mode.
- SSN immediately after pump replacement
- Noisy -Tires or Wheel Bearings?
- SOC won't go above 53-54%
- Summary of common faults/recommended replacements?
- 2008 escape hybrid battery won't recharge
- Scangauge engine temps
- Did the battery blend door actuator replacement today
- SOC Discharge rate
- Rotor and pad replacement
- Engine block heater install question
- Dorman vs Ford for MECS pump
- Rack and Pinion Assembly Gear for Sale (Part #6M6Z 3504 AA)
- Stumped: Blower Motor Resistor
- Buying a Used Ford Escape
- Trailer wiring question
- State of Charge (SoC) and OBD2 bluetooth adapters
- Ford dealer and MECS pump replacement
- Replacing shocks & struts on my '06 - tips for DIYers.
- Replace factory radio? 06 WITH nav.
- Need info on hybrid battery channel
- 2006 FEH gas gauge drop after fill-up
- Miami '06 FEH in Need of Tires
- Miami '06 FEH Power Steering (Rack and Pinion Gear Assembly) Issue
- The Hybrid Myth
- 3rd option on AC control doesnt work
- Costs to replace front wheel bearing
- 12 volt outlet not working
- Stop Safely Now
- Ford Dealer can't solve 12V Battery discharging
- Just bought '08 FEH - Already got Stop Safely Now
- 12V battery discharging - '05
- Possibly to Replace Bearings on 08' FEH ?
- New To Hybrids - Have a couple questions
- Stop safely now error 2006 FEH
- Hybrid and dogs in cargo area causing hot battery.
- Stop safely now at higher RPM only
- 2006 FEH Stop Safely Now
- 2008 Escape will not start in hybrid mode
- Should I buy a 2006 Mariner Hybrid?
- Stop safely now message
- Aftermarket Air Filter, Engine and Hybrid Battery?
- scanguage reading question
- 08 Leaking Washer fluid
- Recharge my ac
- Nav buttons suddenly dead! 2008 FEH
- Flapping Sound: EVAP Purge Valve!!!
- Right Side Tone Ring Is Junk!
- Best Year of the Ford Escape Hybrid???
- Abs light on then off then car skidding light flashing on/off
- Trans Axel cooler vent
- Weird events - won't start- replace 12v batt - then no brakes. Now Stop Safely Now?
- Extrange behavior of engine fan
- 2008 FEH Key Shell Replacement
- 2008 MECS pump replacement - part # question
- Exhaust Flex Coupling Failure
- Slightly smashed oil fillter element
- No 2012 FEH? :( Anyone have hard info on CMax?
- I'm BACK in the hybrid world with a '10 Escape Limited Hybrid--and LOVE IT!
- Escape Hybrid^2
- 05 FEH Thud when coming to a stop
- Flashing airbag light
- Solar charging the 12v battery
- good feh mech. in N. Alabama
- tire size
- At what temp does "Stop Safely Now" happen?
- Rattle in driver door window
- 2005 Escape steering question
- Help! Stop safely and bad dc converter. Need a hand
- 08 FEH - Noise from Wheel Well when turning
- When to Replace Tires With Big Road Trip Planned
- New Owner Question
- Replace factory stereo 2006 FEH
- Used 2006 FEH
- eBay: 2008 FEH Retired Taxi...322,161 miles
- Cargo Area Cover
- "Stop Safely Now" when towing
- PC Card in Mercury Mariner Hybrid NAVI
- DIY Oil Change; some really dumb questions
- Has anyone tried Plug-In Supply? (Battery Upgrade)
- Metalic noise when in bumpy roads
- PTU Oil Change at 54K- it needed it
- Repair or replace windshield?
- Solar Car Charger (cigarette lighter type)
- cd cartridge- FEH 2006
- Gas Gauge- inaccurate FEH 2006
- Thinking I need a new coolant pump but want to be sure
- Battery Cooling Fan Question
- Brakes on Hybrid the same as reg. Cars?
- FEH moving Forward when in Reverse
- Wrech Light
- 12V Cigarette Lighter Socket
- More speed on Electric
- I want to install USB-NAV radio
- Would this be a better Scangauge II?
- Service engine soon gremlin
- Can't get to Points of Interest etc on Nav while you are moving??
- Re-Charged My Air Conditioner Today
- Airbag Light = Engine Shut-Off
- Ford Dealer REFUSING to Honor 8 Year/100,000 Mile Warranty on High Voltage Battery
- odd ABS activation
- 2006 Escape Hybrid brake faliure
- Extended warranty past 100,000 miles
- 2012 Battery Fan Noise
- RPM noise on 2007 FEH
- Ceramic brakes OK?
- 2005/180,000 miles? should i chance it?
- Climate controls not functioning & at idle they kill the car
- Anyone do a seat swap on their escape?
- Easter Eggs in FEH?
- Is there a trailer back there?
- Brakes recalibrate?
- How is MPG calculated?
- Tail lights -seperate fuse?
- 2007 Escape Hybrid will not start
- 05 FEH Used Oil Analysis
- Loud Squeaking - Bushings on Strut
- Slid off the road and broke trans shift cable tab
- Gas Filler Flap Missing?
- Are the electric motor and generator whine louder on cold startup?
- 2007 FEH: Cracked plastic on liftgate
- Is a slight reverse to forward "half shudder" normal?
- 06 FEH, Vibration at 15mph Only...
- Electrochromic Mirrors on FEH with homelink
- Dealer is trying to convince me to drain and fill cvt yearly
- Help - my 12v battery is dead :(
- Extremely Poor Gas Mileage with '05 Escape FEH AWD - PLEASE HELP!!!
- Can you selectively inactivate AWD to FWD on 2012 FEH?
- 2005 Nav Sys Disks
- Kleenex travel size tissues - Target $1.49
- Winter tires
- Rear window washer and wiper 2005 FEH
- Inspect wheel ends for end play and noise
- Wankel Rotary w/base/Atkinson/Miller cycle modes.
- What is the bump sensor on the top?
- I want to modify the Escape Hybrid
- ICE wont shut down
- Message Centers on Escapes
- 2006 ford escape hybrid rear vibration
- Service Manual anyone? I need help with rear hatch lock
- Can you charge an auxiliarly battery with FEH?
- Highway Hypermiling techniquie - Has anyone tried this?
- Radio,GPS,CD buttons do not work
- MPG Drop since getting Oil Change ???
- Difference between 2011 & 2012 Hybrid?
- Finally had to replace the 12v battery
- Cooling System Flush (System Tablets?)
- Aftermarket struts and shocks
- For those who have the block heaters
- Went to the dealer to get a key made.
- 09' Escape rear end "clunk" from reverse to drive
- Trouble During Recalibration
- Navigation Cd's for GPS, 2005 Ford Escape 4WD
- Heat in EV on 09 FEH - How does it work?
- Kuga already in Russia
- Dtc 789
- FEH El Salvador users/owners data - spare parts & Service Manual
- "Service Soon" and the "wrench"
- FEH 07 breaks
- Heater not working
- odd electrical glitch
- Behind-Dash Noise (Heater/HVAC Maybe?)
- front axle replaced at 39,000 miles
- Key Reminder Bell
- Quiet Tires - Finally!
- No More 4WD, and Few FEH
- Oil Analysis?
- Replacement Stereo Recommendations for 2006
- Buying a used Escape Hybrid
- chirping sound
- Canada Wrench Sign/Traction Blend Door Actuator
- Aero Mod
- What This a Recalibration Event?
- MECS question
- Low Gear Advantage While Braking?
- i seriously need help. dead battery maybe? FEH
- my engine has a rod knock
- When to Replace Fuel Filter: 2007 FEH
- used escape hybrid
- FEH 2008 Kicks Butt on Camping Adventure
- Transaxle Lubrication
- Front Brakes - lessons learned
- Longevity of electronic coolant pump
- FEH FWD vs. 4WD for cargo trailer?
- Hypermiling Clarification
- High RPM's in the heat
- Normal operating temps
- Wheel Bearing
- Help in " High motor temperature"
- 2009 FEH steering problems
- Reprogramming Keypad
- Ford and Toyota partnership
- FEH'08 stops using EV (battery) after it reaches 100F
- Help!! No electric assist. Extreme heat??
- Quiet Forum-Mileage on short trip
- Brake Pads @ 110,000 miles
- Wierd squeaking noise
- MPG on recent road trip
- General Grabber HTS?
- when to use L range in FEH
- Ford escape hybrid ac vent temps
- FEH air conditioning
- 12v battery vs. MPG?
- 2013 Escape
- replacing factory nav radio with after market radio
- Insulating the High Voltage Battery?
- Ford & Escape Hybrid Marketing
- Best Jack Placement for Tire Rotation
- Are there any tricks to jump starting another vehicle with an FEH?
- Wrench Sign On for a while
- Internal Transmission Filter on 2006 Ford Escape Hybrid?
- Battery replacement
- Serpentine Drive Belt Diagram
- Completely removing/installing new receiver
- The "330V battery" from inside...
- leak behind intake manifold
- Brake Job on 08 FEH
- Fuel and Distance to empty
