Trailer wiring question
Old Oct 12, 2012 | 03:24 PM
us035976's Avatar
Default Trailer wiring question
Just got a '05 escape Hybrid and am going to install a trailer hitch and wiring. (don't worry it's only for a small utility trailer (usually only 5-800 lbs. I have a Chrysler T&C for heavy towing).
Thinking of using a Hopkins 46365 Short Proof Power Converter (Amazon) for the light wiring. It says it "Requires Installation Of Battery Feed Wire". Does anyone know if there is a 12v live wire available in the back end that I can use for this so I don't have to run one from up front. I will if I have to, but don't want to if I don't have to.
Rich
Old Oct 12, 2012 | 05:24 PM
travelover's Avatar
Feral Engineer
Default Re: Trailer wiring question
I had to run a wire from the battery on back. It wasn't a bad job - just follow the rear AC lines that run front to back. I put mine in a flexible plastic sheath to protect it from abrasion.
Old Oct 15, 2012 | 03:03 PM
us035976's Avatar
Thanks. I kinda figured I wouldn't get lucky and have power already in the back end. Will plan on running a wire from up front.
Thanks!!
econoline
Nov 21, 2013 05:18 PM
PHANTOMMADMAN
Jul 27, 2007 06:19 AM
PflHybrid
Toyota Highlander Hybrid
16
Jul 12, 2007 07:35 PM
prstone50
May 11, 2007 07:37 PM
HoslerD
Oct 14, 2006 04:37 AM
