More speed on Electric
Old May 4, 2012 | 04:26 PM
hc45's Avatar
Exclamation More speed on Electric
Hello, as all knows, the FEH 2006, change from electric to gas about 45, it is possible to make any change into the software to make it to 60 or 75... i have only 2 month with the FEH ... and i can't be in electric very much ... the gas pedal is too much sensitive...
Any suggestion ?
Thank you
Herm.
Old May 4, 2012 | 06:56 PM
Default Re: More speed on Electric
No. You will not be able to change the transition from EV to ICE ( which occurs at 40mph max)
Old May 6, 2012 | 05:59 PM
bumpncarstereo's Avatar
Any suggestion ?
Thank you
Herm.
I am going to guess that you are talking about KPH?
I was hoping the same thing, I feel that the cut in should have been 35mph. I believe the Prius is 35. I agree that the pedal is too touchy. I would love the ability to hit 33/34 then coast to 29/30. Alas I haven't found anything that allows it to be changed with something like a tuner/ programer.
Old May 9, 2012 | 10:09 AM
hc45's Avatar
Exclamation Re: More speed on Electric
There is something we can do with the pedal. . 'cause about the software will be veeery complicated.. making the pedal harder... uhmm i don't know..
There should be a technique... i still thinking...
Regards.
H.
Curated Content Editor
Dec 20, 2012 05:11 AM
jpezz
Oct 26, 2008 04:10 AM
2008 Honda CIvic Hybrid
Feb 15, 2008 11:39 AM
pptudela
Mar 26, 2007 09:44 PM
ChicagoMariner
Jul 12, 2006 11:09 PM
