Serpentine Drive Belt Diagram
Old Jul 12, 2011 | 08:21 PM
grnhybrid's Avatar
Lt. Green 06 FEH
Default Serpentine Drive Belt Diagram
where can I find the Drive belt diag for my 06 escape Hybrid?
Much shorter belt than the xls, but cant seem to locate a diag or instructions to replace...
jt
Old Jul 12, 2011 | 08:35 PM
MyPart's Avatar
Default Re: Serpentine Drive Belt Diagram
Here's a diagram from page 292 of the '08 FEH owners guide (Second Edition)
Old Jul 12, 2011 | 10:19 PM
econoline's Avatar
From the workshop manual removal and installation is just two steps:
1. Rotate the accessory drive belt tensioner ccw and remove the accessory drive belt.
2. To install, reverse the removal procedure.
Old Jul 13, 2011 | 08:05 AM
grnhybrid's Avatar
Lt. Green 06 FEH
I assume thats the tensioner at the top?
How is it rotated? Wrench at the center nut?
thanks to both of you for the help.
jt
Old Jul 13, 2011 | 06:08 PM
econoline's Avatar
Not sure, but looks like it from the diagram.
I haven't changed out a serpentine belt on the FEH, but if it's like my Blazer, just take the biggest crescent wrench you have to the center nut of the tensioner, and rotate to relieve tension. The belt pretty much just drops off the pulleys. It's a very easy job. Save the old belt for a spare.
Old Jul 15, 2011 | 09:33 AM
Rotating the tensioner is to detension the belt. Usually a socket wench over a nut in the center of the roller will work.
Old Sep 16, 2011 | 08:46 AM
schorert's Avatar
Good info here, I just changed my belt last night.
You do not need to lift the car and remove the lower panel the three forward pulleys are relatively simple to reach and thread, the rear can be easily reached around the lower shroud. I was surprised, I snuck my hand up under the shroud and there was the pully.
the tensioner is a *****, getting the old belt off is simple, 11/16ths socket turned counter-clockwise. to put the new belt on is difficult as you have to move the tensioner from it's fully open position to a spot where it can accept the new belt, so you have to move it from say 2 o'clock to 11 o'clock, this involves kind of muscle-ing the rachet handle past the coolant resevoirs. it is possible to push using both hands, then you can hold it in place with fingers of one hand while popping the belt on.
took me probably 40 minutes to get it all figured out, if I had to do it again I could do it in ten minutes max.
Old Sep 16, 2011 | 10:15 AM
grnhybrid's Avatar
Lt. Green 06 FEH
Thumbs up Re: Serpentine Drive Belt Diagram
Defintley good info, thanks much schorert
APuzer
Aug 4, 2024 02:44 PM
HCivHybrid2005
Jan 25, 2013 09:57 AM
lifespeed
Apr 7, 2011 12:22 PM
bwilson4web
Aug 20, 2006 01:16 AM
raypou
Jun 23, 2005 09:00 PM
