PDA
View Full Version : Ford Escape Hybrid
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. 08 Ford Escape not going into EV mode
  2. 2007 FEH Shop Manual
  3. Noise, Anti-Freeze, Engine not shutting off
  4. ABS Light, on and off
  5. Towing a 4wd on a dolly for +-20miles
  6. Repair FEW/MMH Battery
  7. Brake caliper piston stuck
  8. 2005 FEH problems: P0455, radiator fans won't shut off, sulfur smell, high-revving
  9. Selling 08 Escape Hybrid battery pack
  10. Airbox mod results
  11. Somebody know what this sound may be?
  12. How to fill transmission fluid ?
  13. Wheel well rust
  14. Is it doable to swap Escape's Hybrid battery?
  15. 09 FEH sit for about a year, can't jump star
  16. Can't find the jump start button...
  17. OEM brake pads question
  18. should we or shouldn't we?
  19. Transmission fluid leak
  20. 2006 FEH to 2017 RAV4H
  21. ABS + Trac Fried Module?
  22. P0138 Check Engine Light
  23. To Fix or To Sell?
  24. Camper Towing
  25. 2005 FEH Not Starting
  26. HV Battery Jump
  27. Help Picking Kit for Radio Install 2008 FEH
  28. 100k Service: advisable to go to Dealer?
  29. 2006 FEH completely dead
  30. Auto Stop in Defrost
  31. KYB shocks and loaded struts report.
  32. My 08 Escape only gets 32 MPG. Does it mean my HV battery not good?
  33. 08 Won't Start
  34. *sigh* I can tell it's winter...
  35. 2009 Ford Escape Hybrid HVAC not functioning properly
  36. Water pumps
  37. 4WD Lockup/Disable
  38. 2005 FEH experiencing high Rev and lack of horsepower at highway speed
  39. P2004 Error Code
  40. What temperature will the blend door stay closed below? Also, A/C for battery
  41. Looking for HV Battery cooling fan
  42. Low assist with good battery temperatures
  43. If both hybrid and regular batteries are dead, jump start won't work?
  44. Does a failing blend door actuator always throw a code?
  45. Buying used FEH - which model years are best?
  46. Ssn / p0a81, p0a27
  47. Rear differential
  48. Brake pumping noise
  49. 2008 FEH totaled, need help with replacement
  50. Tire choices for 2016
  51. Thinking of buying a 1st Gen Hybrid Escape, can the sat nav be installed?
  52. Transmission Issue? Slipping?
  53. 07 Escape Hybrid AWD way over-filled tranny fluid
  54. Just picked up 2008 Escape Hybrid
  55. I see now why AC work for these is so $$$
  56. MPG drastically reduced when using A/C
  57. Low SOC after sitting a few days
  58. New 2005 FEH Owner with 3 Questions
  59. Finding your door code
  60. 2008 Traction control light when braking and stutter
  61. My new 06 MMH with 282k miles
  62. Battery Life Concern/Question
  63. Used HCU won't accept new VIN
  64. 2006 FEH will not go into Hybrid mode after 30 minutes... help...?
  65. FEH Return
  66. 08 AC problems
  67. 2008 FEH 150K miles - chassis repair priorities?
  68. How do you change the PTU(transfer case) on awd escape hybrid?
  69. Squeeking sound
  70. Help!!!! P0a0a no start
  71. Getting P0171 code after replacing PCV valve & hose
  72. Need information urgently. For those who changed their transmission fluid please read
  73. Clunk upon accel and decel, metal in cvt fluid
  74. 2006 Ford escape hybrid showing battery fan codes
  75. 2008 FEH Brake Sound
  76. Need part #s for HVB cooling fans
  77. 2005 FEH 144K mile report
  78. Both HV battery fans not working. 2005 Escape Hybrid
  79. read the NHTSA complaints on the 2006 FEH
  80. please advise on cracked toner ring
  81. P0A81 (HV Battery cooling fan) + EV mode questions
  82. New 2008 FEH owner
  83. 2009 FEH with Stuck Fuel Guage
  84. Replaced My Front Lower Control Arms
  85. Considering a 2008 FEH with 56k miles
  86. 2005 FEH High RPMs - Redline
  87. Issues remain after replacing MECS pump
  88. Cricket noise from top center dash??
  89. Blower motor replacement
  90. Stop Safely Now, then Poor Regen Braking
  91. Test drove a 2007 FEH, weird substance on oil filter cap
  92. Using an unchipped key to unlock wheel
  93. FEH Engine
  94. 2007 FEH blown engine.
  95. FEH Scan gauge Question
  96. Which provides more charge: braking or downshifting '09 FEH?
  97. Tav on scan gauge is 104 degrees... What to do?
  98. 2005 FEH MECS pump recall
  99. Where can I get a new shift knob for FEH 2008?
  100. Can I Install Newer Factory Head Unit in 2008 FEH?
  101. 2007 FEH, weird issues
  102. Troubleshooting the radio AUX
  103. OBDII Bluetooth Apps vs Scangauge
  104. Average distane in EV Mode on a 2006 FEH?
  105. EV Mode with Defrost On
  106. What P.M. to do now
  107. 2008 FEH not going into electric drive mode in cold weather
  108. How to buy salvaged parts??
  109. Escape Hybrid "Stop Safely Now" message
  110. 2006 dead at 205k miles, starting over with a 2009
  111. 2008 FEH AWD Traction Battery Discharge When Unused In Cold Weather
  112. FEH 4wd Motorcycle Carrier hitch setup
  113. Clunk sound - terrible shake/shudder on washboard dirt road
  114. Tune Up Parts & Procedures
  115. Is $9k for 09 FEH Limited with 160k miles reasonable?
  116. 2006 FEH. Jumper switch always flashes slow even with new battery car wont start.
  117. AC Condenser leaking
  118. 2008 FEH Brakes Process Bleeding and Installing
  119. 2007 FEH power steering failure
  120. 2016 RAV4 Hybrid will be on market
  121. Want to purchase an 07 FEH, advice?
  122. Tone ring
  123. Remove front passenger seat and brakes out
  124. How hard is it to replace the dash panel lights?
  125. 2006 - Stop Safely Now - Dealership says Coolant Fan Kit for HV Battery
  126. Need a new Spare tire and Rim?
  127. Am i crazy spending $6k on a 2007?
  128. I think the dealer is trying to rip me off.
  129. 09 FEH Climate Control panel ???
  130. FEH Subwoofer Install
  131. Air Conditioner, Things I learned
  132. 07 radio to nav swap (can't search forum)
  133. FEH 2006 RPM issue
  134. 2006 Not Consistently Going into EV mode, making clicking noise with keyless entry
  135. 2008 ford escape hybrid 160,000
  136. Intermitent Complete Hybrid Battery Discharge
  137. Buying a hybrid with almost 250k miles
  138. Bxt96r500
  139. 12 volt battery FEH 2008
  140. Anyone recommend a FEH Mechanic? Central Florida or beyond?
  141. P2004 Code
  142. PTU/PTO/Transfer Case Replacement and Seals Wild Goose Chase
  143. Battery discharge overnight
  144. Brake Disc Two sides Wearing
  145. 2008 FEH: $657 reasonable for 90k service?
  146. 2007 Escape Flex Fuel hybrid
  147. Long Term Fuel Trim
  148. HV Battery Cooling Fan Replacement
  149. FEH Valvetrain after 500,000 Miles
  150. Pioneer Head Unit
  151. Hybrid Battery Reconditioning
  152. Ford C-Max, Focus production to leave U.S.
  153. Stiff highway steering
  154. High capacity radiator for 2006 Ford Escape Hybrid
  155. Selling My 2006 Escape Hybrid - $4,500
  156. FEH Help
  157. Wrench Light - Changed Blend Door Actuator - Light Still ON???
  158. 2008 FEH Clicking Sound When Stopping / Starting - Listen!
  159. 2008 Ford Escape Hybrid No Crank no start
  160. 08 FEH AC and misc
  161. low voltage 12v battery capacity and MPG
  162. ABS Light on, Kicks to gas when brakeing!?
  163. Feh2008 recall 14s05 & 14s19
  164. Need Help Replacing PCV Valve in 2008 FEH
  165. "Klunk" coming from rear
  166. Cold Weather Recomendations
  167. Need 1 HV battary coolant fan
  168. Stop Safely Now...
  169. AWD system broke down
  170. 2008 Ford Escape Hybrid Climate Controls
  171. Removing battery on Ford Escape Hybrid for welding passenger wheel house.
  172. Brake job on 2010 FEH
  173. Just bought a 2008 FEH...Few Questions
  174. 2008 Red Triangle wont start or crank
  175. Just bought a 06 Mariner ABS Light/Service Brakes
  176. how often should you replace oil?
  177. my 2008 ford escape hybrid is not working right
  178. Hybrid Battery Discharged Below 40% Threshold
  179. Oil Change Reminder
  180. Interpreting Freeze Frame Data for P0171 Code
  181. Feel Like I'm Being Taken for a Ride - Stop Safely Now
  182. I need a new/refurbished battery pack
  183. Lost heat in EV last night
  184. 2009 FEH Fuel Filling Issue
  185. Wheel Bearing Failure
  186. 2009 FEH AWD stuck in park, no brake lights!!!
  187. 2006 FEH transmission noise
  188. Scangauge shut my car down!
  189. po128 code
  190. 2008 hybrid Body
  191. Weird issue with starting
  192. Battery Drain - ABS Module Ticking
  193. Newbie Needs Help: FEH 2008, Engine
  194. Help a new FEH owner please
  195. Weird braking issue
  196. Battery drain! Also NAV dvd doesn't work!
  197. Camping with my 2009 FEH
  198. I have a wrecked 2007 FEH. What can I do with it?
  199. Ford C Max Energi
  200. High rpms on highway on flat ground, very low mileage
  201. New Tires, again =(
  202. P0562 Code
  203. Considering a 2010 MMH, have a few questions
  204. Ford Escape Hybrid (2008)
  205. Scangauge codes?
  206. Wheel size
  207. Toiling about oil.
  208. Battery and charging questions
  209. High voltage battery questions
  210. 2009 FEH Starting Issue, Help!
  211. Tire Recommendations for '07
  212. P.I.E. X3 FRDW Harness
  213. Tips for driving up to Denver
  214. Ford Help line - useless
  215. Escape hybrid does not start
  216. Fuel economy decreasing, any tips?
  217. 2018 Ford Escape PHEV?
  218. 250,000 miles
  219. A Fill Up over 15 Gallons?
  220. Blown Motor Question
  221. 600 mile tank club...almost
  222. Malfunctioning Warning Indicators - 09 FEH
  223. P0128 sensor or thermostat?
  224. Lower arm/ball joints
  225. Steering issues - squeak and clunk
  226. looking for hybrid battery replacement
  227. Replacing 2005 FEH NAV/Stereo
  228. Rear brakes dragging on rotors
  229. Different MECS Question- multiple failures
  230. Dont forget about your 12V battery!
  231. repacking wiring
  232. Hybrid battery air filter
  233. 2009 FEH drive seat not going all the way back?
  234. 2005 FEH 100,000 mile report
  235. Hub Nut Torque Spec
  236. Engine/transaxle mounts??
  237. p1450 code
  238. Satellite Module
  239. Need someone with expert hybrid experience
  240. Help with Weird Engine Noise, Please
  241. Looking for 120vAC to 24vDC converter for HV battery heater
  242. FEH 2008 - Suddenly cant use keys.
  243. Blend door part #?
  244. External Chirping Sound, 2007
  245. Turn signals blinking fast after deer hit
  246. Mitsubishi Outlander PHEV, FEH Replacement?
  247. Chirping sound in Escape '08
  248. When should my '06 kick into EV?
  249. Sise mirror heaters
  250. Ford recalling 2005-2008 FEH for MECS Pump
