ABS Light on, Kicks to gas when brakeing!?
Old Jun 15, 2015 | 02:52 PM
ddderek's Avatar
Greenie
Question ABS Light on, Kicks to gas when brakeing!?
Well let's open my can of worms... My daughter brought home our 2006 Ford Escape Hybrid and told me the ABS light is on.
When I went out and test drove it the service brakes message was showing. I reset that and then drove it. The ABS light went off for a minute then came back on for the rest of my drive.
The really weird thing is that when in electric mode, it would kick into gas mode every time I used the brakes! And it wasn't because I drained the battery as this was all in our subdivision... This is exactly the opposite from what it should do!? Any ideas on where to start?
Old Jun 16, 2015 | 02:12 AM
lolder's Avatar
Default Re: ABS Light on, Kicks to gas when brakeing!?
Take it to the Ford dealer.
Old Jun 16, 2015 | 03:32 PM
ddderek's Avatar
Greenie
So helpful ! Let me get my check book first!
Old Jun 16, 2015 | 03:57 PM
lolder's Avatar
Ford is the only place likely to diagnose a problem like this. Sorry.
Old Jun 17, 2015 | 07:31 AM
D-mac's Avatar
If you want to start throwing parts at the problem, you could start with replacing the ABS brake tone rings. It's a common issue and a few people have posted about it in the past.
Old Jun 18, 2015 | 12:54 PM
xspirit's Avatar
I suggest you buy the relevant Ford service manual in software form. Even if you don't resolve the problem using the manual, at least you'll be able to narrow down the possibilities and so be better equipped to avoid paying for unnecessary repairs. I refer to the manual every time something goes wrong with my FEH. And that's a lot.
Old Jun 27, 2015 | 09:45 AM
Check the tone rings first. I had a problem like that and it turned out to be a failed wheel bearing causing the tone ring to contact the wheel speed sensor. Turned out it was the last wheel I checked, oh well, but as I took off the wheel it was wobbling from the failed bearing and the cause was obvious. Replaced the wheel bearing and had to replace the speed sensor also, no biggie. The tone ring was just fine.
The related issue is that the regenerative braking can't work properly if the system can't tell what is going on with the wheels. The tone ring eating into the speed sensor takes that away and so the system does funny things like what you've seen.
rotorhead87
Jun 21, 2013 10:14 AM
cowboy
Jul 29, 2012 07:36 PM
Cozdiver
Mar 17, 2009 03:12 PM
dcoleman
Aug 29, 2008 04:58 PM
08hybridok
Feb 20, 2008 12:22 AM
