High rpms on highway on flat ground, very low mileage
Old Feb 21, 2015 | 06:05 PM
hondarider90's Avatar
Default High rpms on highway on flat ground, very low mileage
My 2008 Ford Escape Hybrid is an AWD model with about 147,000 miles. Recently it will be on the highway and running at 3000 or more rpms on the highway at 72mph vs about 2400 that it used to run with the same tires it has now. It typically gets about 23 on the highway now or less. It runs slightly rough at low idle (when the idle comes down below about 1200). It had new plugs in the spring and does not trip any codes. The oil seems to consistently get filled about a half quart high by the shops. I don't think that would cause high rpms though. The charge/discharge gauge is in the middle when it's on the highway. It isn't a battery issue as far as I can tell it is not doing a recal.
Old Feb 23, 2015 | 11:17 AM
GatorJ's Avatar
Default Re: High rpms on highway on flat ground, very low mileage
Is it going into EV mode normally during around town driving?
Old Feb 24, 2015 | 08:55 AM
D-mac's Avatar
I had similar symptoms to you with rough idle and lower mpg. Took it in to a Ford dealer and they had their fuel trim technician look at it. One of the MAF sensors turned out to be bad. The check engine light never came on, but the Ford tech was able to find it after a while on the computer.
There could be other issues going on with a high miler such as suspension/alignment, drivetrain, etc...might take some study to sort everything out.
Old Feb 28, 2015 | 05:43 PM
It goes into ev mode around town once it's warmed up. It takes a really long time in the winter, but I don't think the thermostat is bad because I checked before and it will reach 190 on the highway. The MAF sensor sounds like a good place to start, that could cause a lot of performance issues.
stevedebi
Aug 2, 2009 02:37 PM
mudhutnurse
Jun 10, 2009 06:54 PM
shine5555
Feb 22, 2007 11:19 AM
Anlesauk
Jul 19, 2006 07:09 PM
