2008 Traction control light when braking and stutter
Old Sep 11, 2016 | 09:06 PM
dd0's Avatar
dd0
Default 2008 Traction control light when braking and stutter
Applying the brake on a decline usually triggers this light. The way I would describe it when I brake is it seems to stutter a bit, but it does brake. It usually lasts about 1 second while braking, then stops stuttering and then the brakes are fine. This stutter only occurs about 10% of the time under normal braking, but almost always on a decline.
It's very slight, but the the TC light always comes on in conjunction with the stutter in the brake. Wheel speed sensor? Hydraulic pump? I did notice around the pump the lines have some slight corrosion.
Old Sep 20, 2016 | 05:52 AM
08hybridok's Avatar
Default Re: 2008 Traction control light when braking and stutter
IDK if it would only happen that small amount of time; but I've read elsewhere the tone rings on the Escapes are notorious for breaking (just google/youtube it) can be a DIY fix if you have the time/tools.
Old Dec 6, 2016 | 09:07 PM
trussmonkey666's Avatar
Delayed response here but my 20087/08 had a tone ring break last year as well. With your same findings.
Old Dec 6, 2016 | 10:06 PM
08escapehybrid's Avatar
Yeah, when they get really bad it will kinda "buck" then eventually disable anti-lock. If you are still having the problem let me know, I have a full set of manuals.
Old Dec 7, 2016 | 05:58 AM
wptski's Avatar
Imported from Detroit
They use a wheel bearing where the actual reluctor ring is built into one side of the shield on the bearing. I'm assuming they are going to these now instead.
Old Dec 7, 2016 | 09:49 AM
They may be going to those on new vehicles, but it's not the new spec on our older vehicles. My guess is because they had so many problems with it they changed design. I had all 4 wheel bearings replaced and still have regular old tone rings.
Old Dec 7, 2016 | 09:51 AM
The stutter is either a bad pickup coil which is possible or more likely a bad tone ring, they're incredibly common especiallly in the rust belt.
Old Dec 7, 2016 | 10:13 AM
wptski's Avatar
No, they can't because the sensor and its mounting position are different.
The Ford tech that post many videos stated that he never had to replaced a wheel speed sensor.
dmstroupfl_17
12
Jan 14, 2022 07:56 PM
LakeSilverado
12
Nov 18, 2013 10:16 PM
hybridbob
Jan 17, 2011 03:27 PM
bwilson4web
Aug 4, 2010 08:08 AM
eessydo
Toyota Highlander Hybrid
Mar 27, 2008 04:31 PM
