Battery Drain - ABS Module Ticking
Old Mar 21, 2015 | 10:17 AM
travelover's Avatar
Feral Engineer
Default Battery Drain - ABS Module Ticking
I posted this at Escape Central too, hoping to double my chances of an answer.
My battery is draining while parked and I find it has a steady 0.6 amp draw. While under the hood, I noticed that even with the key removed, the ABS module is making a tic -toc noise with an accompanying pulse you can feel on the module surface. So, I suspect this is causing the drain.
Any ideas of what is wrong?
Old Mar 21, 2015 | 10:50 AM
econoline's Avatar
Default Re: Battery Drain - ABS Module Ticking
Just a longshot, but I'd try pulling the underhood relays one by one and see if the ABS noise stops. Iirc, there are six identical relays in a black box. Maybe one of them has failed closed. Gary G recommended carrying a spare relay for troubleshooting.
Old Mar 21, 2015 | 11:03 AM
travelover's Avatar
Feral Engineer
Thanks - did that (and carry extra relays). I did find that if I connect the battery directly (no ammeter) there is no ticking, so maybe I introduced an anomaly. I'll try pulling fuses one by one.
BABYACCORD
Oct 23, 2013 09:56 PM
UWAdventurer
Aug 13, 2013 09:34 AM
PStewart
Honda Insight
Jul 22, 2011 03:54 PM
Ian
Jun 19, 2007 08:05 PM
bwilson4web
Apr 20, 2006 11:05 PM
