DIY Repair of traction blend door actuator
Old Dec 1, 2009 | 04:40 PM
Default DIY Repair of traction blend door actuator
At this link: http://www.escape-city.com/viewtopic.php?f=24&t=1229 is a DIY guide for repair of a known issue. There are photos as shown here: Name:  FEHblenddoorLargee-mailview.jpg
Can anyone now do this repair and post "real" photos to make the job even easier?
Old Dec 2, 2009 | 07:49 PM
Default Re: DIY Repair of traction blend door actuator
This is a scanguage xguage photo of a normal working traction motor blend door of a 4WD vehicle.
Old Dec 3, 2009 | 07:24 AM
juniorbill's Avatar
I'd be game to tackle this (been getting an intermittent wrench light on my new-to-me 08), but what do I do when I get to step 16?
16. Reprogram the Traction Battery Control Module (TBCM) to the latest calibration using IDS release B52.5 and higher with Patch 7.
Old Dec 3, 2009 | 09:53 AM
stevedebi's Avatar
I would think that the code would be the same for FWD as AWD... or do you know differently?
Old Dec 4, 2009 | 06:12 PM
Thumbs up Re: DIY Repair of traction blend door actuator
Cool. Thanks Billy. And Carl.
Old Dec 4, 2009 | 06:19 PM
I hope everyone realizes this information is from Carl (Desert Dog) and not from me. For the 4wd version TXD 076xxxx is used instead of 045xxx.
Try it and report back on the findings.
Old Dec 7, 2009 | 09:45 AM
stevedebi's Avatar
So that is the first number, which is already 076? Not the 2nd number, which has 045 already? I read the post as being for an AWD, which is what I have.
Old Jul 31, 2010 | 07:34 PM
mijohnst's Avatar
so if i want to check my blend door operation...i just get a scanguage2 ..hook it up and..???? what parameters am i checking? What do other 3 numbers mean...and what is 0000DTC??/ I have 06 mariner hybrid with 138kmiles....and want to make sure things are working properly...i got the dreaded wrench light that went away after next startup....so id like to get SC2 and catch the code sometime
Old Aug 1, 2010 | 04:22 AM
Go to scanguage.com and read up on this piece of hardware that you have to program (input) "numbers" to display information.
Old Aug 1, 2010 | 02:02 PM
colchiro's Avatar
Mijohnst, they're suggesting you program an "x-gauge" on a SG2 to read the blend door status.
