Clunk sound - terrible shake/shudder on washboard dirt road
Old Dec 9, 2015 | 01:57 PM
Lebdog's Avatar
Default Clunk sound - terrible shake/shudder on washboard dirt road
I recently purchased a used 2006 Ford Escape Hybrid 2WD (actually my girlfriend did). Well, we got a good price for the car, and hoped we wouldn't suffer terrible problems I have seen reading this forum.
We hear a slight front end clunk (sounds metal on metal, and I even feel it slightly in the steering wheel) when we are traveling less than 10-15 mph and run over bumps. We live on a dirt road, and when we drive over the wash board (repeated small bumps) sections, the clunk becomes a shudder.
We replaced all shocks and struts initially just to freshen up the suspension. We replaced all outer tie rods, the stabilizer links trying to troubleshoot the clunk with out mechanic. Today I even had the mechanic check the sub frame bolts which were perfectly secured. The mechanic is baffled, and so am I.
I think we replaced every suspect component except for the control arms which appear to be fine, even when pried with a pry bar.
Any assistance from prior owners would be greatly appreciated, because I believe this shudder may eventually damage this car if it's not repaired.
Thanks for reading this.
Old Dec 9, 2015 | 06:37 PM
xspirit's Avatar
Default Re: Clunk sound - terrible shake/shudder on washboard dirt road
This is a long shot, but since you've already checked a lot of things... When parked, try jiggling the steering wheel back and forth less than an inch. By doing this I was able to determine that my '09 FEH had a loose bolt in the steering column. Again, unlikely, but as you said you can't be casual about the steering system.
Old Dec 10, 2015 | 09:54 PM
Lebdog's Avatar
Thanks XSpirit, I did what you said with the motor turned off and could hear and feel something loose. I really appreciate your I reply, and will have my mechanic get on this. I will let you know how it goes next week;-)
sami1
Aug 8, 2015 07:15 AM
bmgoodman
Mar 15, 2012 05:05 AM
Fastforward
Jun 18, 2011 10:30 AM
hchluv
Jan 14, 2010 12:42 PM
feg38
May 16, 2005 11:06 AM
