When should my '06 kick into EV?
Old Sep 25, 2014 | 01:49 PM
Mikeyy's Avatar
Default When should my '06 kick into EV?
My '06 takes at least a few minutes of idling, or even a few miles of light town driving before kicking into EV. I've read it should only take a few seconds to kick over. I bought the '06 a few weeks ago, so I am new to it; it has 50,000 miles. How long should it take to kick over to EV after ignition? Am I just impatient? It's summer here, hot temps at times, no cold weather yet this year.
Old Sep 25, 2014 | 09:03 PM
us035976's Avatar
Default Re: When should my '06 kick into EV?
It won't go into EV mode until the cylinder head temp (CHT) get up to 190. This will take between 1-2 miles depending on the temp outside.
Old Sep 26, 2014 | 07:08 AM
wbonville's Avatar
I have an 08 and in the summer, it'll generally kick off within 5-10 minutes after everything warms up. In the winter, all bets are off and I often am either in EV for a very short time (because things cool down so quickly) or not at all because its simply so cold.
Old Sep 26, 2014 | 08:21 AM
GatorJ's Avatar
That's normal if starting with a cold engine. My 06 won't go into EV mode until water temperature hits 160-165 degrees.
Old Jun 15, 2015 | 06:46 PM
ddderek's Avatar
Greenie
Never... it's too old!
Old Jun 16, 2015 | 02:10 AM
lolder's Avatar
If you have the AC on the ICE will run whenever the AC compressor needs to run. In the winter, it will run to heat the cabin. In later model years the AC compressor was HV electric and the ICE didn't need to run.
jnr
Oct 16, 2017 12:07 PM
tsumeone
Aug 27, 2014 02:46 PM
ericbecky
Events & Gatherings
May 2, 2008 09:37 AM
shu246
Apr 28, 2008 07:55 PM
ben_hch
Aug 23, 2006 05:58 PM
