how often should you replace oil?
Old May 12, 2015 | 04:46 PM
vafa's Avatar
Default how often should you replace oil?
how often do you guys change your oil in your FEH?
in the manual in my 08 it says every 10,000 miles but that seems a bit much.
i usually replace the oil in all other cars in about 4000.
did some research and there are a-lot of people who say in new engines you don't need to change the oil as often and some people stick to 3-5000 mile oil changes.
who should i listen to?
when do you guys change your oil?
Old May 13, 2015 | 09:23 AM
econoline's Avatar
Default Re: how often should you replace oil?
I just follow the Ford recommended 12 months or 10k miles and change when the dash indicator says it's time, Mobil 1. Being a hybrid the engine spends little time idling so the oil has an easy life. At one time I had Blackstone Labs analyze oil samples at 10k and 20k and the oil was still perfectly serviceable when I changed at 20K. Seems to me that reduced maintenance is one of the big advantages of a hybrid.
Old May 14, 2015 | 11:05 AM
OT7's Avatar
OT7
Every 12 months with Mobil 1.
Old May 14, 2015 | 09:39 PM
vafa's Avatar
do you guys use synthetic? if so why?
Old May 14, 2015 | 09:50 PM
xspirit's Avatar
I have it done every 6 months. That would be about 7000 miles. Last time I noticed the mechanic had put synthetic in it. I don't put enough miles on a car to worry about wearing out the engine, and most of the mileage is highway, so I don't worry about doing it more often. Besides being a hybrid, as was mentioned.
Old May 18, 2015 | 05:33 AM
Depends on what you want. If you're a 100,000 miles kind of guy, follow Ford's recommendation.
I use Synthetic, have an automatic pre-lube pump installed, a 1µ bypass oil filter, and an 8µ main filter. I do oil analysis and have never had a sample come back unserviceable even at 30,000 miles.
Still going strong.
Old Jul 7, 2015 | 10:58 AM
I always use Mobil 1.
I always go at least 15,000 miles.
(at 185,000 miles now)
Once I went about 18,000 miles and sent a use oil sample to Blackstone Labs. It was still very clean and had an estimated 20% life left to the oil.
namaste
Jul 31, 2007 03:12 PM
Kintak
Jul 27, 2006 07:11 PM
Momboy007
Mar 31, 2006 05:28 PM
wwjdrv
Jul 28, 2005 07:58 AM
