P2004 Code
Old Aug 4, 2015 | 05:46 AM
dvalley49's Avatar
Default P2004 Code
So after successfully making one 2005 Ford Escape Hybrid out of two (See separte post regarding discharged Hybrid Battery issue), the only significant issue I now have is a P2004 code. The FEH drives fine but the code is not allowing the car to pass emmissions, and it needs to be fixced in less than a month or I am liable for penalties.
It is related to the IMRC system at the intake manifold. The solenoid has been replaced. I believe I have the vacuum lines back on correctly. The spring loaded damper actuator lever is not binding and is moving freely. I hope to take a closer look at it this coming Friday. Does anyone else have any experience with this issue, and have any sugestions on what else to look for or how to diagnose?
Thanks,
Doug
Old Nov 22, 2016 | 08:57 AM
Veets's Avatar
Default Re: P2004 Code
Hello DValley49,
Did you ever figure out what was causing your P2004 error code?
Veets
Run_n_Late
Jun 17, 2006 12:08 PM
MMooney
Feb 28, 2006 09:05 PM
n1ywb
Jun 29, 2005 02:07 PM
Stevo12886
Off Topic
Jun 12, 2005 11:14 AM
JackC
Off Topic
Feb 19, 2004 11:43 AM
