2009 Ford Escape Hybrid HVAC not functioning properly
Old Dec 8, 2016 | 02:10 PM
Msdp's Avatar
Default 2009 Ford Escape Hybrid HVAC not functioning properly
My 2009 Ford Escape Limited Hybrid Electronic HVAC controls are not functioning properly. When I turn on my vehicle and try to turn on the heat using the auto control button on the driver side I heard a clicking noise coming from underneath the drivers dash board. The heat does come on so it's not the blower motor but does not come out of the right vents. Also I tried to turn on my window defroster as well as my floor heat and neither one works properly. Again the heater does blow hot air but no air comes out of the defroster vents or floor heater vents. I am thinking my HVAC blending actuator is bad but not 100% sure. Any help or ideas would help greatly.
Old Dec 9, 2016 | 02:04 PM
08escapehybrid's Avatar
Default Re: 2009 Ford Escape Hybrid HVAC not functioning properly
First thing to do is replace the blend doors if you are hearing strange noises similar to a coffee pot or clicking. It's time consuming, but relatively easy. There are plenty of videos online. They're a common mode of failure for the ventilation system. I think there are three in the dash, while you're in there you might as well do them all. I think they're about 30 a crack.
Bazzetta
Jul 1, 2016 04:28 AM
Mt hood cruiser
Mar 12, 2012 05:30 PM
Alaska
Ford Motor Company
Feb 16, 2012 10:14 AM
greenhome
Jun 14, 2007 11:18 AM
EricGo
Jun 13, 2005 05:06 PM
