12 volt battery FEH 2008
Old Aug 11, 2015 | 06:52 AM
Sazghool's Avatar
Exclamation 12 volt battery FEH 2008
Greeting all
i have feh 2008. I want to replace 12 volt battery by new one. Unfortunately, i did not find motorcraft brand here in my country, even i did not find same specifications. So, the most closed specifications i found is 290cca. Any advise ? Our climate is moderate.
Thanx
Old Aug 16, 2015 | 05:16 PM
travelover's Avatar
Feral Engineer
Default Re: 12 volt battery FEH 2008
CCA doesn't mean much for a hybrid as all the cranking amps come from the traction battery. You basically just need enough power to run the computer. So, practically any 12 volt car battery should do.
Rickhandling
Jun 22, 2012 10:36 AM
IgorC76
Jan 31, 2009 10:23 PM
cmcd
Oct 27, 2008 03:59 PM
doctoru2
Mar 21, 2007 05:03 PM
ManyMPG
Honda Insight
Aug 5, 2005 01:03 PM
