AWD system broke down
Old May 28, 2015 | 12:52 AM
Sazghool's Avatar
Default AWD system broke down
Hello everybody
I have FEH 08. last month I changed front pass. side bearing wheel.
After that, I got the following failures :
1- AWD system broke down
2- rear brakes broke down
3- fron wheels slip when accelarete
I went to a mechanic, no codes were showen. On other hand, I have no any light on dash board.
Any help please
Old May 29, 2015 | 10:27 AM
Default Re: AWD system broke down
I've had such symptoms. In my case they indicated a bearing failure. Those kind of symptoms may show a tone ring (the toothed wheel that indicates wheel speed) eating into the wheel speed sensor. Another possibility is a broken tone ring (they do that from corrosion under the ring splitting it). 1st check each tone ring, 2nd look at the rest of the wheel bearings.
Note: if the computer can't tell the wheel speed of all four wheels, it disables the AWD feature.
diver110
Feb 18, 2011 09:04 AM
econoline
Aug 2, 2006 04:58 AM
cdbrow1
Jul 19, 2005 08:35 AM
lars-ss
May 9, 2005 09:41 AM
eak354
Feb 23, 2004 07:37 PM
