ABS + Trac Fried Module?
Old Jan 28, 2017 | 09:18 AM
howudodat's Avatar
Default ABS + Trac Fried Module?
2010 FEH 65k miles. Battery went dead while my wife and I were in Africa. Daughter jump started it, then ABS and Trac Control lights came on (also hybrid works, but no regen braking). No problems before the jump. Lights come on with ignition on, never go off.
Went to scan, scan tool says communications failure. Took it to the dealer they say the ABS module is fried - want > $2k to replace it. I figured I'd check the fuses and thought I'd find 2 for the brake module a 50A and maybe a 5 or 10A. I can only find 2 50A fuses, one marked brake control module the other brake control module solenoid. Am I missing another fuse somewhere? Can you really fry a module with a jump? Anything else I can check? Finally is it worth trying to find a module salvage, or should I just man up the $1000 for the part?
Peter
Old Jul 27, 2017 | 11:54 AM
howudodat's Avatar
Default Re: ABS + Trac Fried Module?
Finally got to replacing the ABS module today. That didn't make any difference. Still has ABS and TRAC control lights on. I'll take it back again to see if it can scan the ABS module. Anyone have a wiring diagram for this car? I'd like to double check that the module is getting power.
Old Jul 27, 2017 | 01:48 PM
08escapehybrid's Avatar
A low 12v battery will throw all sorts of codes, you should always replace that first when any warning light presents itself.
Old Jul 27, 2017 | 07:36 PM
howudodat's Avatar
I did replace the battery did it right away. Took it in today to have it tested it tested good.
Old Jul 27, 2017 | 11:06 PM
Did the shop mate the ABS module to your vehicle? The vin has to be matched and other parameters.
Old Jul 28, 2017 | 04:33 AM
Rex B's Avatar
Quite a few of the Hybrid supplements to the factory shop manual on ebay for about $20. It's pretty comprehensive.
Old Jul 28, 2017 | 10:42 AM
I have a full set of shop manuals, where do you live?
Old Jul 28, 2017 | 11:13 AM
howudodat's Avatar
Las Vegas, however I just purchased a complete set. They'll probably come in handy in the future.
Old Jul 28, 2017 | 11:14 AM
The troubleshooting in those is an absolute joke. You might get something out of the diagrams though.
travelover
Mar 21, 2015 11:03 AM
fthebault
Feb 6, 2014 08:06 AM
mikieboyblue
Apr 21, 2008 09:59 AM
ESFstevo
Aug 2, 2006 05:02 PM
Orcrone
Jun 8, 2006 03:29 PM
