FEH Subwoofer Install
Old Sep 6, 2015 | 09:16 AM
Organica1's Avatar
Default FEH Subwoofer Install
I am putting 3, 12" Kicker subs in my FEH. Does anyone think the vibration will cause battery issues?
Thank you.
Old Sep 10, 2015 | 03:20 PM
D-mac's Avatar
Default Re: FEH Subwoofer Install
Thank you.
Vibration won't be an issue. The HV battery is good for reflecting sound. Fire the subs rearward and insulate the rear door and you'll have a pretty good platform for generating bass.
You might want to plan carefully on how much power you need to drive 3 12s. It's impossible to upgrade the alternator on an FEH for more power, because there's no alternator. The stock generator is capable maybe of 1000 extra watts for an amp.
You can easily install an Odyssey PC1200 battery in the stock battery tray if you want some more reserve power for your system.
Old Sep 10, 2015 | 03:23 PM
Organica1's Avatar
Thank you, I was going to use a 750-1000W amp that was 1 ohm stable. There will be a 1.3 ohm load then I believe.
Thank you
shoebox303
May 5, 2007 08:13 PM
jbrasure
Nov 29, 2006 04:15 AM
ben_ben
Nov 3, 2006 02:40 PM
DnB
Toyota Highlander Hybrid
Jun 23, 2006 12:10 AM
jjryan
Feb 5, 2006 11:48 AM
