2007 FEH blown engine.
Old Mar 8, 2016 | 10:00 PM
Organica1's Avatar
Default 2007 FEH blown engine.
My engine blew in my 2007 FEH, has anyone replaced theirs? I intend to purchase one on ebay.
Thank you.
Old Mar 9, 2016 | 08:04 AM
econoline's Avatar
Default Re: 2007 FEH blown engine.
Can you give us some details about what happened to your engine? Just curious as an owner of a '07.
If you search for "blown engine" there are several threads to be found.
Old Mar 9, 2016 | 08:08 AM
Organica1's Avatar
Delivered a 50cc dirt bike to a friend and on return trip home; cruise control at 65, engine started to knock, a long grade was approaching and engine had a great loss of power.
Red triangle popped on and gasoline engine shut itself down. I was able to drive EV. Pulled over, no codes found with scan gauge. Towed it home.
Not considering replacement engine, a friend wants $600 to change it.
Thanks. (Up until now my FEH ran the same everyday (AWD) 32-33 AVG MPG 24/7.)
Old Apr 2, 2016 | 09:43 PM
spud's Avatar
Rebuild-able? Thrown rod?
Old Apr 4, 2016 | 07:03 AM
Organica1's Avatar
I replaced the engine myself in my garage, I bought a used long block.
Removing all the hoses is time consuming, separating the engine from the transmission is pretty easy.
I removed my engine from the top, i had to cut into the intake manifold with a saw-zall, the new engine was slid sideways under the car on a creeper and lifting vertically into place with an engine crane.
The car now runs again without any errors and my gas milage is back to 30-32 all the time.
Upon inspection of the old motor, the thermostat was stuck open and it has spun a rod bearing on #1 cylinder.
If you have other questions please ask. Thank you.
Old Apr 4, 2016 | 11:11 AM
econoline's Avatar
Dennis, glad you got it repaired.
How many miles were on the original engine when it failed?
Old Apr 4, 2016 | 11:16 AM
Organica1's Avatar
132,670
The only issue I had with the the vehicle since 2007 was the front coolant pump and the battery fans, both of which I repaired a while back.
When the bearing spun I was going 65mph on cruise control, no lights, no oil light, it just lost a ton of power and the notable tick, tick, tick, tick.
New engine runs great!
Old Apr 6, 2016 | 05:11 AM
wptski's Avatar
Imported from Detroit
This about the third or fourth mentioned in this forum and the owner always gets blamed.
Here's two that I found.
https://www.greenhybrid.com/forums/f...rebuild-25069/
https://www.greenhybrid.com/forums/f...0-miles-22393/
Old Apr 6, 2016 | 05:15 AM
Organica1's Avatar
The engine and CVT do not have to be removed together. I left my transfer case PTO and cvt in place. It slid off similar to a traditional transmission. The (one way clutch) just looks like a dampner with springs in it.
Thanks everyone.
lisamichelle
Jul 25, 2013 09:52 AM
talljetman2
Feb 16, 2009 12:56 PM
AshenGrey
May 22, 2008 06:31 PM
guicide
Aug 2, 2006 03:52 AM
Fernypants
Jun 29, 2005 04:46 AM
