2009 FEH Starting Issue, Help!
Old Jan 30, 2015 | 12:01 PM
Soley4pres's Avatar
Default 2009 FEH Starting Issue, Help!
Hi All..
My wifes 2009 FEH is acting funny. It's not starting well, it takes 5-10 times to turn the ignition to get it to start..
Battery is fairly new and only 38K mi on the car
Help is greatly appreciated , thanks !
Old Feb 8, 2015 | 01:51 PM
travelover's Avatar
Feral Engineer
Default Re: 2009 FEH Starting Issue, Help!
Try jumping with another car it to rule out the battery. It could also be a relay. You can purchase a new relay like is found in the under hood fuse box, and rotate it from spot to spot to see it makes a difference. Also, check for bad grounds / connections under the hood starting with the battery.
twolostminds
Apr 20, 2015 10:48 AM
chartierpw
Mar 24, 2015 06:16 PM
hugoland
Sep 1, 2009 09:06 AM
cooperk851
Aug 14, 2009 04:04 AM
