Log In
View Full Version : Ford Escape Hybrid
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16
  1. No Power steering assist for 2 seconds.
  2. Brake Pad Life for FEH
  3. 2.3L verse 2.5L HEV engine torque verse RPM
  4. What are you guys paying for the Michelin Latitude Tours?
  5. Brake Double-Tap ??
  6. Hybrid vs. 2.3L vs. 3.0 L for mileage
  7. Hello again every body, HV drive start working let me tell u how
  8. 48.563 mpg, in a Mustang!
  9. I need to do light towing with our 2007 FEH
  10. First A/C issue of the year
  11. Brake Service at non-dealer
  12. Renaming the Escape
  13. Service/maintenance schedule ripoff in Vancouver Canada
  14. cabin air filter question?
  15. Relocate A/C Compressor to Electric drive motor
  16. Drag reducing technology located in Miami, Fl.
  17. How long car I safely park my FEH at the airport ?
  18. How long with the 12V battery last in the FEH?
  19. Help: 12V Battery keeps Dying - Brake Pressurizing???
  20. Myth busters Dirty cars get worse mph than Clean cars!
  21. Rear a/c lines replacement & MECS pump.
  22. Mercury Brand Ending this Fall
  23. please look at these photos at the cooling fans
  24. What to offer for a hail damaged 10?
  25. Help - No EV 2006 Escape
  26. Completed 100,000km service 05 FEH
  27. Fuel pump capacity and pulse width for 09 and newer vehicles?
  28. 2005 Escape "High Engine Temperature" Shut Down
  29. Windshield molding question
  30. Reliability Question
  31. 2009 FEHL oil filter - cartridge or spin-on
  32. EPA ratings thru 07 and then afterwards
  33. Small Utility Trailer with FEH?
  34. Low SoC Event
  35. Oxygen generator/separator feasiability..?
  36. Help won't start
  37. "service soon" on 06
  38. Safe source of switched 12V for 2008 FEH ?
  39. 2010 2011
  40. After Market Stereo
  41. '08 Firmware updates?
  42. Trip mpg
  43. Front air dam for better aero?
  44. Stop safely message
  45. to Mr. gray and the professional people here please help
  46. Scan Gauge - Impressions and MPG improvement
  47. How do I drain the engine coolant?
  48. 1200lb cargo load
  49. Cracked Tone Ring
  50. can i get help in my ford escape 2005 EV system
  51. Can't start my Ford Escape - Flood damaged - Please Help!
  52. New Replacment Tires for FEH ?
  53. Another Oil Question
  54. Synch problems
  55. Maintenance Photos
  56. Basic MPG questions
  57. Tweaking the System on the FEH
  58. Short light life?
  59. Changing the fuel filter in 2007 FEH
  60. 100k miles?
  61. What size of Torx wrench is needed for front seats ?
  62. Material used for the Aux A/C Pipes?
  63. Need help diagnosing vibration on my FEH
  64. Heater/MPG Question
  65. just got 2009 FEH 4x4, symbol question
  66. 2010 FEH 4x4 MPG
  67. Sync not syncing.
  68. My Clicking and Knocking Dash Issue
  69. Pulse & Glide
  70. Michelin vs. Continental Tire question
  71. Absoutely Frustrated with FEH
  72. spammers on the forums
  73. FEH - MPG and Hypermiler tips
  74. HV battery issue
  75. Anyone tow with a FEH? MPH?
  76. 2009 with a spin on oil filter
  77. 2005 escape hybrid cv axles
  78. Console - Anyone have an Exploded view?
  79. 2009 and 2010 FEH have same seats?
  80. radiator block
  81. No HEV display on nav sys
  82. New 2012 Ford Escape, But Will There Be a Hybrid?
  83. Brake Boost Pump Noise
  84. New Tip to Save Gas in the cold
  85. Non hybrid question on a 2010 FEH
  86. Noisy Tires
  87. '08 FEH Tranny Problems
  88. '09 FEH Husky Cargo Liner
  89. A coupla questions:
  90. Have pity on a hybrid newb please....
  91. 20K Mile/2 year service
  92. eCVT Tranny Question
  93. Intermittent Wrench Light
  94. Anyone know Nav CD part number?
  95. FEH, Brakes, regen only question
  96. Bought a 2007 with high miles. Was it a good deal?
  97. No heat in EV mode
  98. Best place for an extended warranty online?
  99. After 30-40min of driving will not go into hybrid mode
  100. Vibration at 40-60mph
  101. Need help with GreenHybrid layout
  102. Best place to get a replacement Nav CD?
  103. 10 FEH 4x4
  104. 08 leather seat replacment?
  105. 2008 vs 2009 vs 2010
  106. purchased used, high milage, 2007 f.e.h. - 4x4 so far so good/report
  107. FEH seats change over the years?
  108. Where is the coolant drain?
  109. Any reason to stay away from 2005 FEH
  110. Battery ventilation
  111. Coolant Flush, What do people use?
  112. Towing a U-Haul...they think I can pull this?
  113. Scangauge turns off etc?
  114. Buzz noise at very slow speeds
  115. How the heck to change the Spark Plugs
  116. Look at what could be, HAS been, done.
  117. 37.4F TAV today
  118. Electric Cabin Heater Pump
  119. LV battery
  120. help...please...
  121. This is odd... Or is it???
  122. '10 vs '09 FEH MPG
  123. noises from front of feh during breaking and acceleration
  124. ford escap brak
  125. Good Source for Shop Manual?
  126. Dumb 4x4 question
  127. 2009 versus earlier model FEH
  128. taking FEH 4x4 off road
  129. Lights flicker during Brake System charging
  130. Replacement costs for 2008 Ford Escape Hybrid battery pack
  131. Considering a used 70k mile FEH - Need opinions
  132. 07 Hybrid w/NAV and Sirius question
  133. Help! My MPG has dropped off drastically with my 06 MMH
  134. Cold temperature effect on TAV and BTM
  135. 5 years old and as good as new
  136. noise in front suspension
  137. HEV Fuel Economy Screen Not Working
  138. Radio/AC frame
  139. What is that thing?
  140. Unexpected high mileage over hills
  141. Clicking Sound When Braking/Accelerating
  142. 2010 FEH fuel tank and 4x4 in snow
  143. Linear Logic Scangauge support ?
  144. Front wheel alignment
  145. No ICE with Defrost on in Cold Weather?
  146. end of warranty approaching
  147. Oil filter question
  148. Oil Change Warning
  149. Why you want a front grille air block
  150. My New Favorite Photo
  151. Ford Hybrid Sales in Massachusetts.
  152. 2010 feh awd
  153. DIY Repair of traction blend door actuator
  154. Blend Door Actuator - Again
  155. I don't understand the heating controls....09'...
  156. Hypermiling FE vs FEH
  157. Economic logic of hybrids
  158. Water Pump Dead - Drives Better
  159. 100k Service
  160. How well does the FEH do off-road?
  161. Accidently Drove In Low Gear
  162. MAF sensor dies and dealer says caused by cheap air filter!
  163. Momentary locked steering
  164. Instant economy question
  165. Who is using Mobil 0-W20?
  166. 06 ford escape hybrid, bad brakes
  167. Get it tomorrow.
  168. Internal Cabin Air Filter?
  169. hybrid battery harness recall cost??
  170. OK..here's the thing..
  171. Record low SOC?
  172. FEH Cargo Mat
  173. 2010 feh/ffh rpm
  174. No Charging in Reverse
  175. Very strange electrical behavior
  176. Dfi...??
  177. Couldn't turn key to start 2009 FEH
  178. tpms tool - 06 ?
  179. Tpms sensors are not responding
  180. Can't set the clock
  181. New to Hybrid
  182. 2006 MMH new tires better MPG
  183. Test Drive this weekend - FEH 2006 - New to Hybrids
  184. Just purchased a ScanGauge. How to use?
  185. Trim removal
  186. Anyone using General Grabber HTS tires?
  187. Hybrid wheels vs. Non-Hybrid wheels
  188. Advice on "Stop Safely Now" issue
  189. Check FUel Cap and Service emission Systems
  190. Is a Scangauge worthwhile if you have the NAV screen ?
  191. Electrical weirdness
  192. 5w20 or 0w20
  193. alignment and tire wear
  194. Post Your Battery Recalibration Numbers Here
  195. 2008 FEH Console Mount
  196. 2005 Hybrid Escape (demo) 100k - what to look for when buying
  197. Hybrid Haters
  198. posting with photos
  199. First oil change
  200. Dratted Initial Electric Assist!
  201. Ok...
  202. Trip to Tahoe
  203. increased maintenance costs...
  204. News. STRANGE news.
  205. Is it always better to use EV?
  206. Good news.
  207. Do I Need To Reset The TPMS When I Get New Tires
  208. Changing the Motor and Electronics coolant on an 06 FEH
  209. Dash noise is back
  210. transmission fluid
  211. TPS Throttle Position Sensor
  212. tire pressure monitor questions
  213. 4WD and the FEH
  214. Severe headwind 10-15 mpg hit?
  215. $1,500 tax credit expiring
  216. 2000 mile road trip on E85
  217. Low Cost Oil Filters
  218. FEH and extreme cold climates-any issues?
  219. Fuel level and fuel pumps
  220. Toad Brake for the FEH
  221. Tire sizing question
  222. Engine RPM's Cold & Warm
  223. 2009 FEH Tire Question
  224. Tire / Road Noise issue....
  225. Paradigm Shift: Run A/C to keep your engine cool!
  226. low gear renerative braking (not working)
  227. Brake wear
  228. Fill-up consistency
  229. What happens when Miles to E hits 0?
  230. Replacement Chrome Grill & Bumper Cover
  231. link to 2010 FEH MY OBD System Operation info
  232. link to 2009 FEH Sourcebook & 2009 MY OBD System Operation info
  233. 2010 FEH A/C compressor is electric not belt driven
  234. link to 2010 FEH Sourcebook info
  235. Hood Ajar Message
  236. 1st oil service.
  237. Dome light stuck on
  238. Speed above 40 MPH for highest MPG
  239. What to look for in a used FEH with high milage
  240. Glide Mode
  241. CARS Program New Guidance and Ordering a 2010 FEH
  242. 110V Power Question
  243. 2010 Street date?
  244. Service/Mechanic Recommendations in Los Angeles?
  245. 2006 Escape Hybrid: Catastrophic Engine failure @ 65,000 miles
  246. Many Q's...
  247. FEH "High Motor Temperature"
  248. Beginning HF installation
  249. problem starting FEH
  250. New owner for 2 weeks more questions
