Relocate A/C Compressor to Electric drive motor
Old Jun 9, 2010 | 06:35 PM
rsbrown's Avatar
Default Relocate A/C Compressor to Electric drive motor
I saw that Ford finally decided to fix one of the complaints on almost all hybrid vehicles, that the A/C compressor also stops when the gas engine stops making stop lights uncomfortable. On the 2010 model Ford has moved the Air conditioning compressor to the electric motor which runs all the time, even when the gas engine shuts down. Does anyone have any information on how they did it, ie compressor mounts, pulleys etc.? If it is as easy as welding on or tapping some threaded holes and using the 2010 compressor bracket with whatever pulley arrangement necessary I am very interested in doing that type of conversion.
Old Jun 11, 2010 | 05:52 AM
rsbrown's Avatar
Default Re: Relocate A/C Compressor to Electric drive motor
I found more details about the 2010 A/C compressor, like the Priuses use a Denso electric A/C compressor. I found this thread and it discussed my question pretty well.
Converting to an electric Air Conditioner compressor sounds a little more expensive than just adding a new bracket and relocating the mechanical one. It is too bad because the main electric motor seems to be always running and it would have plenty of power to turn a compressor as well.
Old Jun 11, 2010 | 09:09 AM
Exclamation Re: Relocate A/C Compressor to Electric drive motor
Are you joking? I can't tell on email without something like this:
If you are not joking... you need to do more reading.
The A/C in newer cars is NOT run by the electric motor(s) for the car!!!
The electric "drive" motors are NOT ALWAYS RUNNING!!!
The electric motors are directly connected to the wheels. If the wheels are not turning, there is no electric dirve motor turning. This car has no "clutch".
The A/C in newer cars is a self contained unit that runs by itself on electricity without any pulley whatsover attached to the engine. Or electric drive motors!
Old Jun 14, 2010 | 11:01 AM
stevedebi's Avatar
From his initial question, I cut him some slack. I knew that he meant converting from engine belt driven compressor to electric compressor. I don't know if he realizes that the electric compressor runs off the traction battery.
Old Jun 14, 2010 | 01:29 PM
colchiro's Avatar
Either way it's too expensive to consider.
Old Jun 15, 2010 | 08:55 AM
rsbrown's Avatar
Thanks Stevedebi,
I have been on a road trip from Virginia Beach to Boise, Idaho driving the 06 FEH , So far I am pretty happy with the car aside from the missing A/C at stops,, especially in the very humid Virginia.
Yes, I saw the electric compressor has to run off the main battery because the 12V system just isn't enough to run the compressor. I was just looking for some details on the newer setup to see if it is worth searching for a wrecked FEH with the newer setup.
Old Jun 15, 2010 | 12:51 PM
stevedebi's Avatar
Originally Posted by rsbrown
Thanks Stevedebi,
No, your "Pre-2009" FEH software is not set up to accomodate the electric compressor anyway. It would have a very uncertain effect, and would probably mess up everything anyway, even if you had the equipment.
You do know that if you turn off "ECON" the A/C (and engine) will run at stop lights?
Old Jun 15, 2010 | 01:21 PM
colchiro's Avatar
I assume that what this means, "aside from the missing A/C at stops".
I get along just fine with econ mode, and rarely run the a/c, unless the outside temp is over 90°, rare in the Midwest until July/August.
Old Jun 15, 2010 | 01:59 PM
stevedebi's Avatar
That statement is exactly why I asked. One does not have to do without A/C at stops.
Old Jun 15, 2010 | 02:03 PM
colchiro's Avatar
Sorry, I misunderstood your intent.
