Transaxle Lubrication
Old Sep 4, 2011 | 04:54 PM
Default Transaxle Lubrication
I came across a patent application on "freepatentsonline" that causes me to infer that the FEH transaxle has an oil pump that is geared from the ICE input to the transaxle. Thus it only pushes oil around when the ICE is running. Didn't say this directly but why put in the patent unless you're changing something.
Anybody got any info on this? How about some info on the oil flow path inside the transaxle?
Appreciate it.
Old Sep 7, 2011 | 07:17 AM
Default Re: Transaxle Lubrication
My inference is that the FEH transaxle either runs on residual oil, has a "drip cup" high in the transaxle case that is filled while the ICE runs, or just uses MG 1&2 to sling oil around when the ICE is off.
So I'm wondering if there's a time element to how far/how long you can go on the battery.
Winchester_Fire
Aug 3, 2013 04:08 AM
bwilson4web
Jun 15, 2006 05:40 PM
bwilson4web
May 24, 2006 08:16 AM
bwilson4web
Apr 18, 2006 12:17 PM
bwilson4web
Jan 22, 2006 07:35 AM
