High RPM's in the heat
Old Aug 26, 2011 | 11:30 AM
08hybridok's Avatar
Default High RPM's in the heat
Is excessive heat same as excessive cold as far as the ICE goes?
I know in winter, near 0 the engine will 'idle' at ~2200rpm, ie when coasting at speed where it'd normaly drop to ~1500rpm, it stays up.
Now that's it's 110+ every day it seems to be doing the same thing, is it running AC for the batt to keep it cool, and that's why it stays up?
Wish there was a working BTM for the SG for the 08's
Old Aug 26, 2011 | 12:17 PM
Default Re: High RPM's in the heat
Yes. In my 2005 FEH the idle rpm is as much as 600 rpm higher when I have both the front A/C on Max. and the battery needs cooling at the same time.
While there are two cooling loops with two freon evaporators, there is only one belt driven freon compressor. The compressor cannot compress enough freon for both loops at low rpm.
John
Old Aug 26, 2011 | 02:42 PM
stevedebi's Avatar
It is probably coincidence, but mine appears to happen right around 96 degrees exterior temperature. It adds about 500 RPM.
Old Jul 6, 2017 | 08:23 PM
miguel's Avatar
John
sAME THING HERE WITH MINE AT HIGH TEMPS 96+ ADDS 600 RPM WITH AC ON.
Old Jul 7, 2017 | 04:59 AM
Rex B's Avatar
TAV - Average Battery Temperature - works in my '08
Tareqkiram
Mar 17, 2014 06:35 PM
Geckoboy
Jul 13, 2013 08:52 AM
mudhutnurse
Jun 10, 2009 06:54 PM
gte473f
May 4, 2008 08:47 AM
MrCrank
Dec 8, 2007 05:26 PM
