RPM noise on 2007 FEH
Old Mar 20, 2012 | 04:40 PM
badpelican's Avatar
Default RPM noise on 2007 FEH
My 07 FEH has 82K miles and hasn't had any issues. Its still performing as always but now makes a noticeable sound that seems to correspond to wheel rpms. It can be heard with and without the ICE running but if for example I am cruising at a constant 45 MPH but just slightly alter the pressure on the accelerator it can make the sound change in intensity.
If on a steady downhill below 40 mph with the ICE off the sound can be heard and is altered by just slightly applying or releasing pressure on the brake pedal.
Hard to describe the sound other than its not an irritating screech but more like something isn't quite lubricated enough or something is slightly contacting something else that wasn't happening before.
Any thoughts? I'm taking it in soon for service anyway but was wondering if anyone here has an idea.
Old Mar 23, 2012 | 12:55 PM
stevedebi's Avatar
Default Re: RPM noise on 2007 FEH
Sounds a bit like my recent problem, although I noticed it more when turning. They replaced the front strut bushings and everything is quiet now.
Old Apr 5, 2012 | 02:15 PM
badpelican's Avatar
Default Power Take Off Unit
Took the FEH in to the dealer finally, turns out the noise was caused by a failing power take off unit. $900 part plus labor ends up as a mere $1600 fix - ouch!
mppkll
Jul 1, 2014 05:16 AM
robh2
Nov 16, 2009 01:05 PM
andrewbmoore
Oct 28, 2008 05:27 AM
doctoru2
Mar 21, 2007 05:03 PM
Ian
Oct 16, 2006 05:55 PM
