2007 Ford Escape Hybrid and non-Hybrid Engine differences
Old Feb 24, 2014 | 04:42 PM
MrFixit1328's Avatar
Default 2007 Ford Escape Hybrid and non-Hybrid Engine differences
Does anyone know what the differences in a 2.3L engine in a 2007 Ford Escape Hybrid versus one in a non-Hybrid are? I understand that there is a difference in the timing. I'm not sure if the cams are completely different or just the gears. I would also like to know if there are any other differences. Basically, I want to know what I have to do to a 2.3L non-Hybrid engine so it can be used in a Hybrid?
Old Feb 24, 2014 | 04:46 PM
Billyk24's Avatar
Default Re: 2007 Ford Escape Hybrid and non-Hybrid Engine differences
Why are you looking at using a non-hybrid motor to be used in a hybrid vehicle?
Old Feb 24, 2014 | 04:52 PM
They are much less expensive and more available.
Old Feb 24, 2014 | 05:59 PM
GaryG's Avatar
Different camshafts, compression ratios (pistons), starting systems etc. The block maybe the same.
Gary
Old Feb 24, 2014 | 07:45 PM
GeorgiaHybrid's Avatar
Crank, rods, pistons, camshafts are a given. The ECU, fuel injectors, starter (hybrid doesn't have a conventional one) and cylinder head are the other likely possible differences as well.
Old Feb 26, 2014 | 12:05 PM
D-mac's Avatar
The e-CVT is also a big difference between a hybrid and non-hybrid. You'd probably have to ditch that transmission if you wanted to de-hybrid a FEH.
There have have been people on this site who claimed to have rebuilt the engines of FEHs (even with junkyard hybrid motors). But these days I bet not that many people are going to want to sink that kind of money in to a 8+ year old Escape.
Old Feb 27, 2014 | 04:25 AM
I'm not trying to de-hybrid my FEH. I need to either replace the motor or rebuild the one I have. I have been told that it is less expensive to get a used engine. I have not had any luck finding a replacement. If the differences were minimal, I would have bought a used used non-hybrid motor, used the good parts off my old motor and bought anything else that I needed.
Old Feb 27, 2014 | 09:04 AM
econoline's Avatar
Just curious about your original engine. How many miles are on it and how did it fail?
Old Feb 27, 2014 | 10:21 AM
Just under 142000 miles. Spun a bearing and intake cam has one worn lobe. Oil level was perfect 1-1/2 weeks before the bearing spun. After it happened I checked the level and it was down 3-1/2 quarts. Signs of oil where the engine bolts up to the transmission.
Old Feb 27, 2014 | 11:49 AM
GatorJ's Avatar
Gary
So you're saying there's a chance?
