Rounded Head in Oil Filter Cover Filter Cap Drain Plug
Old May 24, 2014 | 10:36 AM
GatorJ's Avatar
Default Rounded Head in Oil Filter Cap Drain Plug
2006 FEH
I have found that the head of the oil filter cap's drain plug has rounded out with use.
The Ford part number for the oil cap assembly (the drain plug is not available separately) is 1S7Z6A832BA and costs approximately $40.
There is a Dorman (Chinese made aftermarket) part number 917-004 available for around $12. There are repeated references to poor quality control issues in the Amazon reviews (mentioned in 6 out of the 14 current reviews) and I decided not to go that route.
Mazda part number LF01 14 320 A9U cross references to both part numbers above and sells for approximately $16. It's probably the same part as the Ford one and it has to be better than the Dorman, so this seems like the best choice.
Old Jun 1, 2014 | 04:49 PM
travelover's Avatar
Feral Engineer
Default Re: Rounded Head in Oil Filter Cover Filter Cap Drain Plug
I never use the drain plug on the oil filter cap anyway. I just unscrew the cap and let it drain into a pan. A failure of this part would be a disaster, so tread carefully.
Old Jun 2, 2014 | 08:57 AM
nitramjr's Avatar
I took mine off a couple times but realized there was no point. If the cap is taken off carefully, it doesn't really make a mess.
If the plug is in there tightly, I'd just leave it an never open it again.
Old Jun 3, 2014 | 05:42 AM
GatorJ's Avatar
Even if you don't drain the filter, I would still change the 0-ring periodically as it was not intended to be permanent.
Old Jun 3, 2014 | 05:52 AM
travelover's Avatar
Feral Engineer
I wouldn't bother. There are O rings internal to the transmission and engine that are there for life. What damages them is turning the plug.
Old Jun 6, 2014 | 12:03 PM
Cool Re: Rounded Head in Oil Filter Cover Filter Cap Drain Plug
My small drain plug is also rounded.
It has not been opened since 2007! no drips!
I see no point to it either.
MichelleVueHybrid2009
Saturn Vue Green Line
Nov 8, 2009 04:10 PM
HiCap
Aug 26, 2008 09:05 AM
phendyr
Apr 15, 2008 07:46 AM
mmrmnhrm
Mar 25, 2007 11:00 PM
LarsBoelen
Website Questions & Input
Sep 24, 2005 10:07 AM
