CVT Transmission
Old Apr 2, 2014 | 01:55 PM
sullyr1's Avatar
Default CVT Transmission
I have a 2008 Ford Escape Hybrid and I think I'm having a problem with my transmission. While driving the car, as I speed up the car/transmission is not downshifting. Has anyone had this problem or any suggestions? It's a CVT type transmission.
Old Apr 2, 2014 | 02:15 PM
GaryG's Avatar
Default Re: CVT Transmission
All Ford Hybrid have eCVT and they don't up shift or downshift.
Gary
Old Apr 2, 2014 | 04:15 PM
GeorgiaHybrid's Avatar
As noted above, CVT transmissions don't "shift" gears as they use a variable gear ratio that matches engine demand to speed and torque requirements.
Old Apr 3, 2014 | 12:13 AM
Shogun's Avatar
Sounds like a typical CVT to me. Theres technically not, "gears" like a traditional transmission has, so theres really no downshifting.
Old Apr 3, 2014 | 04:54 AM
wptski's Avatar
Imported from Detroit
News flash! Chrysler, who doesn't even have an hybrid, electric, etc. uses a variable ratio non-shifting transmission in some of their vehicles.
Old Apr 3, 2014 | 06:50 AM
us035976's Avatar
I assume you are a new FEH owner. My question is: Does the engine NOT rev up as you press harder on the accelerator? My first impressions when I got my FEH a year and a half ago was sorta the opposite - Isn't this thing ever going to UPshift? I'd back off because of the higher revving than I was used to with a regular tranny. Now I just let'er rev up knowing it'll slow down as I gain speed.
Has anyone ever heard of the CVT not working right and 'smooth-shifting down' and letting that engine rev up?
Old Apr 3, 2014 | 10:38 AM
Shogun's Avatar
Honda uses one in the non-hybrid 4-cylinder Accord too.
Old Apr 3, 2014 | 12:32 PM
xspirit's Avatar
I think some day people will see the behavior of today's automatic and standard transmissions as torturing the engines by forcing them to operate outside their most efficient rpm's at both ends of every gear change.
Old Apr 12, 2014 | 09:00 AM
TLCinAZ's Avatar
Love my Escape
Does anyone have any facts or opinions about doing a flush on the CVT? I've heard mixed opinions about whether they're really needed if you aren't having any issues... that doing a flush can actually dislodge gunk/particles and cause problems. Thanks!
Old Apr 12, 2014 | 09:42 AM
GaryG's Avatar
All FEH's have a lifetime fluid from the factory for the sealed eCVT. More people void their warranty by changing the fluid and using a non approved fluid. This is not like the old automatics with torque converters that needed flushing.
Gary
