Bought a used FEH 2006
Old Jul 4, 2013 | 06:32 PM
el_pablo's Avatar
Unhappy Bought a used FEH 2006
Hi,
Today, I just bought a used FEH 2006. It was a federal government car.
The car have the following problem which was listed in the ad (link) :
  • Driver's door does not unlock with the remote
  • Rear whipper does not work
  • Rear brakes need to be replaced
  • Front brake lines need to be replaced
I drove it back home (160 km - 100 miles). Here is what I notice :
  • A/C does not seem to work.
  • It never ran on EV mode since I drove it back home.
  • I think it was full and the car drank 20+ litres (5.3 g) for the trip.
The car have not run since last november and It was quite hot today around 30°C (86°F).
So why the car never went to EV mode and why it burnt so much gas!?!?
Thank you
Old Jul 4, 2013 | 06:39 PM
Billyk24's Avatar
Default Re: Bought a used FEH 2006
See this link for making the remote work: http://www.ehow.com/how_6199609_prog...d-key-fob.html
Brakes and brake lines are items that wear out on all vehicles including hybrid.
Rear wiper not working--someone will have to check the motor, electrical connections, etc.
AC doesn't work-bad compressor, low on fluid, etc. Needs to be checked out.
Doesn't go into EV mode--could be due to a failing MECS pump, lack of air conditioning to the hybrid battery via the cooling lines under the vehicle, could have an issue with the hybrid battery pack fans not working, could be an issue with the blend door stuck in the closed position.
Federal Government vehicle? What agency keeps the vehicle for 6+ years before getting a replacement? Where did you find this vehicle?
Old Jul 4, 2013 | 06:42 PM
el_pablo's Avatar
Done it. No work.
Hmmm... Canadian gov't Check the link in the original post.
Old Jul 5, 2013 | 10:27 PM
elborak's Avatar
Cheapskate
Could be the Smart Junction Box. See https://www.greenhybrid.com/discuss/...eplaced-25092/.
erms32
Feb 11, 2013 09:19 PM
FirstCar20
Aug 26, 2012 04:36 PM
prairieclover
Apr 3, 2009 05:36 AM
rickpoet
Nov 7, 2008 12:58 PM
Escape_from_Hanover
Jul 16, 2008 07:59 AM
