replacement battery in 05 FEH?
Old Mar 29, 2013 | 02:20 AM
cowboy's Avatar
Post replacement battery in 05 FEH?
My battery needs replacement under the hood. Should i get Motorcraft or after market! Battery is only at 325 cold cranking amps should be 500.
It defiantly needs replacement in the near future.
Any thoughts?
Is there anything I need to do other than pull the old battery, like pull any fuses under the hood.
1st time replacing battery in this car.
Just want to make sure I don't damage the car when replacing the battery!
Old Mar 29, 2013 | 11:05 AM
travelover's Avatar
Feral Engineer
Default Re: replacement battery in 05 FEH?
I bought an aftermarket battery and installed it myself. Just make sure that it fits right. CCA mean nothing on a hybrid. You might want to plug in a small battery to the cigarette lighter so you don't have to reset your radio presets.
Old Mar 29, 2013 | 11:46 AM
us035976's Avatar
Ford has a rebate until 3/31 on their batteries. Check http://owner.ford.com/servlet/Conten...iceCouponsPage (near the bottom) for details. I just replaced mine and am waiting for the rebate. Cost after the rebate will be about $100 (installation included). I coudn't find a better price for a decent battery, so I went with the Ford Motorcraft one.
Old Mar 29, 2013 | 05:52 PM
D-mac's Avatar
The 05-08 FEH uses a BCI size 96R battery, there are a couple of aftermarket brands now that sell them like Sears DieHard and Interstate. Careful not to let a shop sell you a bigger battery for a regular Escape, it won't be secured properly in the tray. Since you've had such good luck with the stock battery, you probably don't need to spend extra $$$ for an gel-cell/AGM battery.
If you're feeling extra spendy Motorcraft I believe sells a couple grades of their 96R batteries.
xspirit
Oct 1, 2014 03:44 PM
84GT Ragtop
Aug 11, 2012 04:24 PM
anuckols
Jul 5, 2011 07:32 AM
gpsman1
May 12, 2008 05:54 AM
smogless
Sep 27, 2005 11:45 AM
